Originally Posted By: mechtech2
Originally Posted By: SteveSRT8
It depends on WHEN... see the smoke at actual ignition? Then it's usually oil.
Need to wait a few minutes? Figure moisture.
If that engine has very many miles it'll have a ton of oil and residues in the intake manifold. This can mimic valve seal issues.
Don't be fooled.
Interesting point about oil in the manifold [common], but this would flow and burn all the time, not just at start up.
Just depends on the manifold design. Since most are not heated and the mfgr's know about the oil issues they allow for it to pool somewhere. Enough of it does flow all the time to keep it from overflowing, but if the car is flogged a bit this never happens. It's only 'city cars' that get this issue to a point where it can cause a noticeable problem.
Needs a good run up to 140 or so! Send me the keys.
Don't be fooled.
