Wiha screwdrivers
by Donald
02/08/16 05:05 PM
How Can I Print 755 Mailing Labels For Post Cards?
by crazyoildude
02/08/16 04:17 PM
Valvoline Full Synthetic High Mileage and Blend HM
by mctmatt
02/08/16 03:59 PM
Delo 400 Severe Duty?
by 333jeffery
02/08/16 03:56 PM
2016 Civic sedan is selling very well
by HTSS_TR
02/08/16 03:24 PM
Oil suggestion for 2013 Honda CR-V
by Mar57
02/08/16 03:02 PM
STOP CALLING ME!!!!
by NHHEMI
02/08/16 02:33 PM
Need oil suggestion for high mileage 2003 WRX
by xmakeafistx
02/08/16 01:09 PM
09 VW Passat Wagon 2.0TSI 4900mi Castrol 0w40 Euro
by gerkin85
02/08/16 12:48 PM
Oil/filter recommendation for short trips
by DrRoughneck
02/08/16 12:46 PM
Auto Zone brand oil on clearance (YMMV)
by blupupher
02/08/16 11:20 AM
M1 5w30 HM / 5512 Miles / Turbo with Towing
by Astro_Guy
02/08/16 11:10 AM
slewman, lithium1189, Monktana, djh3, Compignite
56850 Registered Users
93 registered (87sammy, Al, 2010Civic, 97f150, 8 invisible), 1647 Guests and 230 Spiders online.
56850 Members
66 Forums
244413 Topics
Page 1 of 2 1 2 >
#2709265 - 08/08/12 09:58 PM Dirt Bike Rod bearing seizure (pics)
jamesm113 Offline
Loc: CA
My 2001 Yamaha WR250F's rod bearing seized on me. I barely put 4 hours of use on it before it seized. The oil level was halfway between the hash marks. Anyway, I was hoping someone could identify what caused it to seize. I had someone press it apart. The needle bearing shattered into pieces.
#2709273 - 08/08/12 10:03 PM Re: Dirt Bike Rod bearing seizure (pics) [Re: jamesm113]
jsnyder49090 Offline
Loc: south haven mi
What do you mean it only had 4 hrs on it?
99 Regal LS
98 Regal GS L67
95 Chevy K1500
83 Buick LeSabre Limited
97 Regal GS L67
78 Granada 42,000 orig miles
#2709296 - 08/08/12 10:27 PM Re: Dirt Bike Rod bearing seizure (pics) [Re: jsnyder49090]
motor_oil_madman Offline
Loc: Houston, Texas
improper assembly most likely.
2007.5 dodge cummins 6.7 liter. Chevron Delo400 15w40. 7000 mile or 250-300hr intervals.
#2709310 - 08/08/12 10:46 PM Re: Dirt Bike Rod bearing seizure (pics) [Re: jamesm113]
expat Offline
Loc: Canada
Looks like it was dry.
Assembly lube?
#2709314 - 08/08/12 10:52 PM Re: Dirt Bike Rod bearing seizure (pics) [Re: expat]
Loc: Houston, Texas
Those scratch marks almost looks like someone pounded the wrist pin on there without any lube. Unless that was you that did that removing it.
#2709430 - 08/09/12 07:07 AM Re: Dirt Bike Rod bearing seizure (pics) [Re: jamesm113]
sunruh Offline
Loc: Cedar Park, TX
you are funny
the wr250f does not have a needle bearing around the wrist pin.
and a 2001 that is 11+ years old with only 4 hrs. right, was it in a museum?
motorcycle oil myth buster
#2709488 - 08/09/12 07:56 AM Re: Dirt Bike Rod bearing seizure (pics) [Re: motor_oil_madman]
AVB Offline
Loc: Georgia
Thats what I am thinking, probably had a broken roller from the start.
#2709841 - 08/09/12 03:00 PM Re: Dirt Bike Rod bearing seizure (pics) [Re: jamesm113]
Errtt Offline
Loc: California
Just curious... what oil was being used?
#2710061 - 08/09/12 06:44 PM Re: Dirt Bike Rod bearing seizure (pics) [Re: jamesm113]
jamesm113 Offline
Loc: CA
Sorry I wasn't clear: I bought it used and I put 4 hours of light use on it before it seized on me.
I don't know what oil was in it, I was going to change it after that ride.
I think the scratches are from removal, but am not sure.
There is a needle bearing for the crank pin, which is pictured (not the wrist pin.. the wrist pin was fine, and like someone mentioned, has no needle bearing)
Edited by jamesm113 (08/09/12 06:46 PM)
#2710235 - 08/09/12 10:00 PM Re: Dirt Bike Rod bearing seizure (pics) [Re: jamesm113]
jamesm113 Offline
Loc: CA
A picture of some of the other parts and the shattered needle bearing:
Edited by jamesm113 (08/09/12 10:02 PM)
#2710453 - 08/10/12 08:32 AM Re: Dirt Bike Rod bearing seizure (pics) [Re: jamesm113]
sunruh Offline
Loc: Cedar Park, TX
yes that can happen on the crank pin, not on the rod.
how plugged was the oil pump screen?
replace it with another oem crank.
doesnt take much oil to keep that bearing alive. so you have/had
an issue somewhere else.
ah now my memory comes back, dang been a long time since i've seen this. this must be a last run of 01 bikes. because this issue showed up on the early 02s.
the oil hole in the crank pin wasnt lined up and so it starved the crank pin. known issue on early 02s.
steve
#2710605 - 08/10/12 10:59 AM Re: Dirt Bike Rod bearing seizure (pics) [Re: sunruh]
jamesm113 Offline
Loc: CA
Oil pump screen was not clogged at all. In fact it was almost perfectly clean. Oil filter had a good amount of metal shavings in it, but it wasn't clogged.
Top end was in good shape, but I replaced the piston and rings anyway.
I've replaced it with a brand new OEM crank (had a superseded part no) and also gave it a new OEM oil pump (which also had a superseded part number). I've also replaced the main bearings, countershaft bearings, and all transmission bearings.
Now I'm worried this will happen again frown
#2710734 - 08/10/12 12:59 PM Re: Dirt Bike Rod bearing seizure (pics) [Re: jamesm113]
sunruh Offline
Loc: Cedar Park, TX
1st off let me say that it was a very limited number of motors that had that issue.
2nd, your bike is 11 years old. yamaha isnt even required to make parts for it.
that motor is designed just like an F1 motor. how many of those are around after 11+ years? or even 2.
#2710903 - 08/10/12 04:22 PM Re: Dirt Bike Rod bearing seizure (pics) [Re: jamesm113]
Cujet Online   content
Loc: Jupiter, Florida
That was a known issue with your bike. Put the new parts in and enjoy it. Make sure your valves are in good shape too. Dropping a valve will ruin your day.
Turbo's rule.
#2714564 - 08/14/12 04:05 PM Re: Dirt Bike Rod bearing seizure (pics) [Re: jamesm113]
jamesm113 Offline
Loc: CA
Cool, and the new crank has the hole lined up properly, I imagine?
Just wanted to make sure I (or the previous owner) wasn't doing anything wrong.
Thanks everyone
Page 1 of 2 1 2 >
