Originally Posted By: cutter
I just purchased a Celica with the 2zz-ge engine and thought about putting in either RP or Toyota 0w-20 for the upcoming winter. The car is spec'd for 5w-30 though, however, in winter I tend to short trip a lot going to work... hmm
Toyota Celica was discontinued in 05 so this engine must have some miles on it. When considering a thin oil, don't forget the mechanical state.
102k mi. With 0w-20 being off spec, would it consume more or would it not protect? I can deal with the former for better startups, but not any instance with the latter.
Burning more oil is never ok, fouls everything between the combustion chamber and the muffler. Cats are expensive on Toyotas. I just looked at the back spec chart. I suspect you have the GTS model which means you have one of the 2 engines Toyota makes that does not have a back spec. Not even 5w20. That tells me all I need to know. Your asking for trouble using 0w20. The cons outweigh the pros.
