Just did a d/f on a family friend's 2003 ES300. It has 113k miles and an indie shop serviced the trans at 98k charging/claiming they dropped the pan and replaced the filter.
I was surprised at how dirty the fluid was considering only 15k miles since last service. Also, the trans was overfilled by a full 2 1/4 qts! On the 98k service, the owner was charged for 6 qts of ATF but a d/f yields only 3.3. Guess you get a little more when you drop the pan. I'm thinking they did a d/f only and added 6 qts or they just added a couple qts without removing any old fluid. Who knows?
In any event, the old fluid was not foamy so can I assume the 2 1/4 qt overfill caused no harm? Thanks.
