I've got '93 Camry SE (3.0L V6 and 5 Speed Manual) with 230k miles on it. The owner's manual calls for 10W-30 (or 5W-30 if it's winter) and I was going to try and switch to a 0W-20 oil, either the Pennzoil Platinum or Mobil 1 Advanced Fuel Economy, and I was wondering if there's anything I should be worried about. I'm also not concerned about the theoretical increase of fuel economy, I just want to try and protect my engine.
I know I will have to make sure I have sufficient oil pressure, and if I don't, I'm probably stuffed, and will have to switch back to a 30 grade oil. The oil also might knock of some of the sludge and carbon build up that's been collecting for the last 20 years, so the oil pressure might drop after a while because of the less restriction to flow decreasing the pressure (clogged artery analogy). It might also just consume a bunch of oil, in which case I'll have to switch back to a 30 grade oil as well. I know I should also check the oil color, and be prepared to change the filter prematurely.
My question is (finally, I know), is there anything that I've overlooked, or is it completely inadvisable? Also, a more basic question, if I have to switch back to a 30 grade oil, shouldn't a synthetic 0W-30 oil be better than the recommended (probably conventional) 10W-30 oil in every way? Better low temp viscosity and flow, same operating viscosity, cleaner, and probably getting up to temp. faster?
