The most common avgas available today is 100LL, which contains appr. 2.0ml/gal of T.E.L. and is dyed blue.(LL=low lead) 100LL is a replacement gasoline for the old 100/130 which had 4.0 ml/gal of TEL, and was colored green. Many WWII-era aircraft required 115/145 octane av gas which was dyed purple and had 4.6ml/gal of TEL. These same aircraft that are restored and operated today are running lower compression cylinders to facilitate operation on 100LL. Aside from 100LL, the only other avgas available today is 80/87, which is dyed red and contains .5 ml/gal of TEL. This stuff is getting scarce, though, so many of us Cessna 150 pilots have to settle for 100LL. Note that XX/YY octane means XX octane at lean best mixture and YY octane at rich best mixture.
Running 100LL will not cause problems in a car as long as you don't have a catalytic converter or an oxygen sensor. The lead may damage these. I have seen many low compressioned, gas-engined aircraft tugs, power units, start carts, generators, light stands, powered baggage ramps, etc. run just fine on 100LL for years. You may occasionally fowl your plugs with deposits from the lead, however. Also it will turn your oil grey and possibly screw up your UOA's. Be sure to tell the lab you are running avgas, if you pull UOA's. It's higher octane may enable you to advance the timing without fear of detonation.
I love avgas. I like the sweet smell, and the fact that if you get it on your person, you don't smell like gas for the next week, like you do with mogas. I especially like the fact that avgas seems to keep for a very long time in storage, and doesn't gum up needle valves, etc in the machinery that it is in. I winter my lawn mower with avgas, and my generator is fueled exclusivly with avgas for this reason.
Where are you getting this avgas? What airport did it come from? What flavor is it? I'm just curious, as I have a small use for it time and again.
[ November 20, 2003, 03:27 PM: Message edited by: ralan ]
