Truck Odometer: 205300 mi
Miles on oil: 18000
2 quarts of makeup oil added since last oil change.
From Polaris Labs.
Wear Metals:
Iron; 60 ppm
Chromium; 4
Al; 5
Copper; 6
Lead; 4
Contaminants:
Silicon; 11
Sodium; 15
Multi-source metals:
Moly; 76
Boron; 39
Additive metals:
Mag; 1193
Calcium; 1114
Phos; 1188
Zinc; 1451
Fuel Dilution Soot Water
KV100 = 14.8 cSt
TBN = 6.46
Oxidation = 13
Nitration = 9
Polaris Comments: Data indicates no abnormal findings. Resample at normal interval.
I swear I've driven this thing 6000 miles between samples, but oil just won't show it! The only thing that has markedly increased is Iron, going from 41 to 60 ppm. At this rate, it will be ready for changing in another 12,000 miles if I hold to a condemnation limit of 100 ppm. I have never gone longer than an 18k OCI, so I'm getting into uncharted territory. Does anybody see any reason I can't go to 30k?
If I'm going to stretch the oil that long, should I change the filter before then? Just make an annual filter change, and change oil when Iron hits 100?
I talked to Polaris Labs, and the tech said their change recommendation for TBN is at 35% of new, which would be 3.7. At the average rate of decrease, TBN would hit that limit in another 29k miles. I don't think that TBN will be the limiting factor on this load of oil.
Miles on oil: 18000
From Polaris Labs.
Wear Metals:
Iron; 60 ppm
Chromium; 4
Al; 5
Copper; 6
Lead; 4
Contaminants:
Silicon; 11
Sodium; 15
Moly; 76
Boron; 39
Additive metals:
Mag; 1193
Calcium; 1114
Phos; 1188
Zinc; 1451
KV100 = 14.8 cSt
TBN = 6.46
Oxidation = 13
Nitration = 9
