People running thru red lights. You ever follow th
by motor_oil_madman
05/03/16 08:30 PM
747-400 versus 747-8
by mjoekingz28
05/03/16 08:22 PM
14psi bypass pressure for small engines?
by motor_oil_madman
05/03/16 07:47 PM
'13 Wrangler 2.5" lift
by JXW
05/03/16 07:37 PM
group 7 v6128 ford 6.7 7k miles
by robo339
05/03/16 07:34 PM
Napa Synthetic
by wolf_06
05/03/16 07:34 PM
How do you guys do it?
by Duffyjr
05/03/16 07:04 PM
House electrical panel buzzing
by Mr Nice
05/03/16 06:15 PM
Happy Birthday Merkava_4
by Trav
05/03/16 04:56 PM
When should you use grease with moly?
by Jetstreamz06
05/03/16 04:54 PM
VOA Motul 4100 Power 15W50
by GermanAutohaus
05/03/16 04:31 PM
Ace Hardware Pennzoil Yellow May 4th to 9th $2.99
by BigD1
05/03/16 04:23 PM
myfarmertan, coachvonyo, ionix, Amtecol, DRAX392
57779 Registered Users
122 registered (69GTX, andyd, AirgunSavant, 2002 Maxima SE, 01rangerxl, ABerns, 9 invisible), 1711 Guests and 319 Spiders online.
57779 Members
66 Forums
248427 Topics
#2697975 - 07/28/12 12:59 PM On 96 Chev Lumi, the w/s wipers don't operate at 1
Jim Spahr Offline
Loc: Lexington, SC
When you cut the wipers on, they do nothing. Then you cut them on high, and finally they work. On all speeds.
Chevy Impala SS 1994 LT1 5.7L V8
Chevy Blazer LS 4WD 2003 4.3L V6
Chevy Lumina 4 door 1996 3.1L V6
#2697984 - 07/28/12 01:09 PM Re: On 96 Chev Lumi, the w/s wipers don't operate at 1 [Re: Jim Spahr]
NHGUY Offline
Loc: USA
Sounds like a switch issue to me.Once you go past the low setting,all is well.That should be the whole multifunction "stalk",not cheap.I would get used to using the high setting then easing back to low.
#2698013 - 07/28/12 01:49 PM Re: On 96 Chev Lumi, the w/s wipers don't operate at 1 [Re: Jim Spahr]
Tdbo Offline
Loc: Ohio
Sounds like a trip to the boneyard is in order. The problem is probably the switch.
2012 Honda Accord LX-P 79K
2008 Ford Mustang Pony Package Convertible 13K
2006 Honda Odyssey EX-L 72K
2003 Ford Ranger 3.0 Supercab 88K
#2698060 - 07/28/12 02:56 PM Re: On 96 Chev Lumi, the w/s wipers don't operate at 1 [Re: Jim Spahr]
Gabe Offline
Loc: Indiana
It sounds like the pulse board to me; they are prone to failure.
Edited by Gabe (07/28/12 03:01 PM)
#2698267 - 07/28/12 07:01 PM Re: On 96 Chev Lumi, the w/s wipers don't operate at 1 [Re: Jim Spahr]
Jim Spahr Offline
Loc: Lexington, SC
Never heard of a 'pulse board' ? Where is it? How hard to replace? In a salvage yard, what do they normally run for? How do I TEST to see if it is a switch or a pulse board? Does anything else run off the Pul. board? I was wondering if that would tell me if it was bad....
