Honda GX35 question
by dirtydannyd
07/25/16 02:08 AM
Need advices for oil filter inspection
by ST2008
07/25/16 01:45 AM
Supertech- ST3387- Virgin cut open
by FordBroncoVWJeta
07/25/16 01:06 AM
Clean battery with garden hose?
by SavagePatch
07/24/16 11:55 PM
Toyota 5w20 blend?
by researcher
07/24/16 11:36 PM
Smoked some baby backs today
by BeerCan
07/24/16 10:28 PM
Ford FWD axle replacement
by 2009Edge
07/24/16 10:27 PM
Saturn ac compressor
by spasm3
07/24/16 10:20 PM
looking for spray guns - analysis paralysis
by tomcat27
07/24/16 10:18 PM
WIX 51372 ADBV Failure
by WellOiled
07/24/16 10:11 PM
moly + engine coatings
by benjy
07/24/16 09:57 PM
Worth the upgrade?
by daves87rs
07/24/16 09:47 PM
curiousaboutoil, 01CAMRY, corndogzombie, NJ1911, SneakyTacos
58587 Registered Users
58 registered (AlienBug, aquariuscsm, B320i, 2009Edge, Astro14, Al, 5 invisible), 1200 Guests and 11 Spiders online.
58587 Members
66 Forums
252222 Topics
#2697045 - 07/27/12 12:06 PM Generic ATF Drain plug.
montero1 Offline
Loc: Md, USA
Looking to put some drain plugs on the ATF pans on my Jeep and Z4. Anyone know of one that works well?
'07 Z4 3.0 SI
'08 GL1800
'09 Sentra (Hers)
'10 Jeep Rubicon
'10 Mini Cooper
'13 V-Star 1300 Deluxe (Hers)
'13 VFR1200F
#2697060 - 07/27/12 12:17 PM Re: Generic ATF Drain plug. [Re: montero1]
Donald Offline
Loc: Upstate NY
How about using a Magnefine filter and that somewhat eliminates draining of the pan. There are several drain plugs on Amazon. Some people weld them in.
2015 Ford F250 w/Powerstroke
2001 Jeep Grand Cherokee Laredo 4.0- sold
1999 Dodge Ram 2500 w/Cummins- 4-sale
#2697074 - 07/27/12 12:29 PM Re: Generic ATF Drain plug. [Re: montero1]
Kruse Online   content
Loc: Kansas
I've used the B&M tranny drain plug on a couple of my vehicles, although I don't currently have a vehicle with it on. It seemed to work just fine. For this application, you drill a hole in the pan, assemble it and tighten the nut. This particular one is available on ebay or a lot of your mail-order shops and quite often it's priced under $10. I think there's also a generic no-name version that's priced slightly lower.
#2697092 - 07/27/12 12:49 PM Re: Generic ATF Drain plug. [Re: Kruse]
montero1 Offline
Loc: Md, USA
Looks like the nut inside the pan that holds it on sticks up quite a ways and would keep 1/6 of an inch of fluid from draining....
'07 Z4 3.0 SI
'08 GL1800
'09 Sentra (Hers)
'10 Jeep Rubicon
'10 Mini Cooper
'13 VFR1200F
#2697152 - 07/27/12 01:50 PM Re: Generic ATF Drain plug. [Re: montero1]
mechtech2 Offline
Loc: Chicago Area
Good call - this is going to be a drawback with most add on plugs.
Still they can be quite handy, even if you are going to take the pan off, it is way less messy. If not, you still get a whole lot out.
If you put one in, weld it or secure it real nice. Like JB weld in addition to the tightening nut.
#2697301 - 07/27/12 04:40 PM Re: Generic ATF Drain plug. [Re: montero1]
JTK Offline
Loc: Buffalo, NY
True, but even pans with a factory plug are threaded or stamped in such a way that that you can't completely drain it. Not a big deal IMO.
Joel
2016 Subaru Forester 2.5, CVT. 2013 Dodge Grand Caravan SE (Babe magnet III)
#2697431 - 07/27/12 07:28 PM Re: Generic ATF Drain plug. [Re: montero1]
KB2008X Offline
Loc: St. Louis, MO.
Before you start drilling holes see if you can't find a pan with a plug at the dealer. They will surprise you sometimes with prices lower than you expected. Then try the aftermarket. Dorman has pans with plugs for many applications. Mopar Performance should have one for the Jeep, as should B&M and the various transmission parts suppliers.
An aluminum pan will offer improved cooling of the fluid in the pan versus the stock stamped steel pan.
Do you go off-road much ? You need to consider ground clearance.
A sixth of an inch isn't anything to be concerned with. Just tilt the vehicle towards the plug, which should be at the rear of pan.
Keith
04 Town Car 4.6 5w20 FL820S
92 Ram D150 3.9 10w30 MO-090
03 S-10 4.3 5w30 Puro L10111
above on TropArtic Synthetic Blend
10 Toyota Camry - undecided
#2698460 - 07/28/12 10:21 PM Re: Generic ATF Drain plug. [Re: KB2008X]
cbear Offline
Loc: Cincinnati, OH
I added one to my Nitro. Here's a thread I did about it.
http://www.bobistheoilguy.com/forums/ubbthreads.php?ubb=showflat&Number=2060806
1995 Thunderbird
2003 Cavalier
2007 Nitro
2001 XLH 883
