R Rick Joined Jan 26, 2003 Messages 491 Location Ottawa Oct 23, 2003 #1 On my topic question, does an ethanol blend gasoline keep your injectors and Combustion chamber cleaner then just running regular gasoline?
U uconn1150 Joined Mar 19, 2003 Messages 700 Location Texas Oct 23, 2003 #2 I think the answer is yes and no. Yes, it will reduce emissions and may clean a bit, but it won't lubricate the injectors--but then add a little neutra and you are good to go!
