Smoked some baby backs today
by BeerCan
54 minutes 27 seconds ago
Ford FWD axle replacement
by 2009Edge
55 minutes 54 seconds ago
Saturn ac compressor
by spasm3
Today at 10:20 PM
looking for spray guns - analysis paralysis
by tomcat27
Today at 10:18 PM
WIX 51372 ADBV Failure
by WellOiled
Today at 10:11 PM
moly + engine coatings
by benjy
Today at 09:57 PM
Worth the upgrade?
by daves87rs
Today at 09:47 PM
Mr. Funnel does in fact work!
by TurboFiat124
Today at 09:46 PM
Will ATP205 help with a head oil leak
by NattyBoh
Today at 09:11 PM
Why is 100% gas more expensive in the city?
by TurboFiat124
Today at 09:06 PM
Trouble getting a copper pipe sweat fitting sealed
by NateDN10
Today at 08:58 PM
Murphy oil
by TurboFiat124
Today at 08:53 PM
NJ1911, SneakyTacos, DaveD, 8o8is, Texasdude74
58584 Registered Users
58 registered (AZjeff, abycat, ag_ghost, Brad_C, barkingspider, benjy, 8 invisible), 1373 Guests and 8 Spiders online.
58584 Members
66 Forums
252216 Topics
Page 1 of 2 1 2 >
#2694085 - 07/24/12 04:42 PM Signs of an oily clutch
JHZR2 Offline
Loc: New Jersey
My 1991 BMW seems to leak a little bit of oil though I can't trace it. Perhaps it burns it though there's no real indication in the exhaust and no smoke. It has the original clutch at 150,000 miles. I'm wondering though about what happens when a rear main seal leaks onto the clutch.
The reason I ask is because when I start off in first gear, the clutch starts to grab just fine. At about the last quarter of the clutch pedal motion, instead of fully catching up it almost feels as if there is a slippage and then it locks up hard. Maybe it is a shuddering sensation as a good way to describe it.
So because of this I'm wondering if there could be oil on the flywheel or clutch that causes such a behavior. It is very intermittent and there is no signs of clutch slippage using any of the typical tests. That's why I have to wonder if there is just a slow leak of oil onto the flywheel that maybe just burns off after a shift or two.
Even if this happens generally if I am shifting a lot in and out of different gears and using the clutch, it will not happen again until I sit for a long time, like either at a long stoplight or turned off the car to park for a few minutes.
So what would it feel like if I had oil on the clutch?
#2694089 - 07/24/12 04:47 PM Re: Signs of an oily clutch [Re: JHZR2]
SteveSRT8 Offline
Loc: Sunny Florida
My old 65 TR4 had a bad rear seal and leaked on the clutch.
It felt exactly as a worn one would, and my test has always been to apply full throttle at peak torque in high gear, perhaps 4th in your case.
Your symptoms sound more like a bad throwout bearing or perhaps a bad slave cylinder/master cylinder
"In a democracy, dissent is an act of faith."
J. William Fulbright
Best ET-12.79 @ 111 mph
4340 pounds, Street tires
Just like we go to Publix
#2694101 - 07/24/12 04:55 PM Re: Signs of an oily clutch [Re: JHZR2]
440Magnum Offline
Loc: Texas
It takes a pretty big rear main leak to actually get on the clutch material in most vehicles. The leak is on the opposite side of the flywheel from where the clutch is, so it has to be leaking fast enough to fling off the flywheel, drench the inside the bellhousing and then drip back onto the clutch. In other words, you usually can SEE oil on the ground long before it would ever get on the clutch.
If I had to guess, yours sounds like the pressure plate is hanging as you release the pedal then snapping the rest of the way in quickly. Maybe because the clutch is worn and the fork (or slave cylinder- not sure how your vehicle is made) is hitting an area of travel near the end of its range.
'66 Dodge Polara & '69 Dodge Coronet R/T both 440/727
'08 Ram 1500 4.7/545RFE
'12 Challenger SRT8 392/6-speed
'99 Cherokee 4.0, '11 Grand Cherokee 3.6
#2694112 - 07/24/12 05:05 PM Re: Signs of an oily clutch [Re: JHZR2]
JHZR2 Offline
Loc: New Jersey
The clutch may be worn given the number of miles on it, but it fully grabs under any test that I do such as those mentioned just above.
Both the slave cylinder and the throwout bearing wear from use, correct? I almost entirely drive stop and go, stop lights and traffic, so a use related wear out would be expected. I never keep the clutch pedal pressed though.
Could it be that the clutch is worn to the end of life but yet grabs fully? I assume I would do the full clutch assembly and slave cylinder all at once not just one or the other? You always do the master if you do the slave, right?
#2694138 - 07/24/12 05:28 PM Re: Signs of an oily clutch [Re: JHZR2]
JRed Offline
Loc: Virginia
It isn't at all necessary to change the slave cylinder when changing the clutch, but it could make the job MUCH easier depending on where yours is.
I've never heard the "always do the master if you do the slave" either. I suppose it's sound logic, but I don't hear of master cylinders failing that often. Then again - maybe dead men tell no tales, eh?
06 Subaru Impreza WRX - Sold. The only mechanical thing I'll ever love.
07 Toyota Prius - Cheap synthetic and PureOne filters.
#2694146 - 07/24/12 05:38 PM Re: Signs of an oily clutch [Re: JHZR2]
TFB1 Offline
Loc: VA
A chattering clutch can be a indication it has gotten some oil on it... With heavy amount of oil, they generally slip with more than light/moderate throttle...
#2694167 - 07/24/12 06:00 PM Re: Signs of an oily clutch [Re: JHZR2]
JamesBond Offline
Loc: midwest
Your description of normal operation during the first part of clutch uptake, then a feeling of slippage, then a hard lock up as you finally take your foot off is exactly how my '87 325 felt when I had a front transmission seal leak. Sometimes it was more obvious than others but was most noticeable on a fast start or during faster driving. The clutch never slipped when flooring it in gear and would always grab hard when you finally let your foot off the clutch.
My clutch had been replaced within a few years so i knew it was not a clutch wear issue but with your miles on the original clutch it could be just worn out.
#2694172 - 07/24/12 06:05 PM Re: Signs of an oily clutch [Re: JHZR2]
silverrat Online   content
Loc: Ontario
I have this happening to my Accord. Slow clutch fluid loss but no leaks.
03 Civic Si(R) - Assembled in Swindon, England
Long Live the Manual Transmission drive
#2694178 - 07/24/12 06:15 PM Re: Signs of an oily clutch [Re: JHZR2]
Lead Shoes Offline
Loc: Mn
Sounds to me like a worn clutch, you would be able to see the oil dripping before you would get it on the clutch.
If it bothers you enough and you plan to keep the vehicle a lot longer, replace the clutch otherwise just try not to notice it and get used to it.
1992 BMW 325i 176k
Castrol 0w40/Mahle
#2694218 - 07/24/12 06:58 PM Re: Signs of an oily clutch [Re: JHZR2]
fdcg27 Offline
Loc: OH
The clutch in our '99 Accord worked just fine with no slip at all until it abruptly failed in service last fall.
When I say "failed" I mean that the vehicle lost all drive in any gear while being driven down an interstate highway.
New disc, pressure plate, throwout bearing and flywheel (micro cracking) and all was like new again.
12 Accord LX 53K HGMO 0W-20
09 Forester 67K PU 5W-30
02 Accord 144K GOil 5W-30
01 Focus ZX3 112K M1 5W-20
95 BMW 318iC 159K Delvac 15W-40
#2694233 - 07/24/12 07:14 PM Re: Signs of an oily clutch [Re: silverrat]
TFB1 Offline
Loc: VA
It doesn't evaporate...
#2694250 - 07/24/12 07:29 PM Re: Signs of an oily clutch [Re: JamesBond]
JHZR2 Offline
Loc: New Jersey
Mine may be the same trans, and it is a good point that I should try to check/change the mtf perhaps if I find it to be low, it would be an indication. The amsoil fluid holds shift feel much better than redline so I haven't changed it in a few years.
#2694562 - 07/25/12 06:53 AM Re: Signs of an oily clutch [Re: JHZR2]
supton Offline
Loc: NH
I've had that feeling on first a Saturn and then my VW. The Saturn would not have it after letting the dealer do an oil change though; I'm guessing the grease monkeys might not drive as nicely as I do... I generally had full clutch engagement around 1000-1200rpm IIRC on the Saturn, still do on my VW. [It hurts to drive the Camry.]
I don't know if it's a drive-by-wire issue on my VW as it is only felt when cold really. Just this sudden lurch as it finishes catching, maybe it's more throttle related. Been doing it for a long time, yet it just got a new clutch at the begining of summer (bad DMF--thanks VW for more stellar engineering) and there was no issue with the clutch disc, oil contaimination, etc.
2011 Toyota Camry, base, 6spd manual, 117k, hers
2010 Toyota Tundra double cab, 4.6L, auto, 127k, his
#2695055 - 07/25/12 04:01 PM Re: Signs of an oily clutch [Re: JHZR2]
mechtech2 Offline
Loc: Chicago Area
A real bad rear seal leak can get on the clutch. It slings all over and then drips down on it.
Normally, a little leak is designed to never hit the clutch - it just goes down and away.
Anyways, an odd thing with fluid on brakes or clutches is that they can actually grab, not slip. The heated goo often makes it grabby.
Is this grabby cold then gets better?
The rubber or metal dampers in the disc can go bad, There is an on/off sensation instead of a smooth transition.
If she does not slip when driving, this may be the problem.
#3919671 - 11/16/15 02:32 PM Re: Signs of an oily clutch [Re: JHZR2]
buck91 Online   content
Loc: West Michigan
How do you differentiate betweeen rms leak and a trans front seal? Little noticeable fluid loss when checked but drips when hot and inside of bellhousing is soaked with dirty mucky fluid.
2011 F150 4x4 5.0L
1996 Mustang GT 5spd/ragtop
1980 Yamaha XS850G
Page 1 of 2 1 2 >
