Hard starting LCT snow engine..
by JTK
02/12/16 02:34 PM
low-temperature oil gelling reversible?
by DrRoughneck
02/12/16 12:51 PM
I HAD to do it!
by Kuato
02/12/16 12:24 PM
Why Erin Esurance vanished from TV
by Benzadmiral
02/12/16 11:39 AM
Engine Light Advice
by coopns
02/12/16 11:14 AM
Caution UOA - PP 10W30 6881m on 2001 Jeep 4.0
by Donald
02/12/16 11:09 AM
What happened to the thin oil movement?
by camrydriver111
02/12/16 10:57 AM
Mastercraft Strategy tires (I'm cheap)
by Bgallagher
02/12/16 10:41 AM
Mobil Delvac ATF in a regular car transmission
by SuperValue
02/12/16 10:35 AM
Dumped the smartphone!
by andrewg
02/12/16 10:27 AM
Need to replace plugs - cooper,Iridium, or Plat?
by MoreCowbellAz
02/12/16 10:25 AM
Child bicycle trailer?
by Quattro Pete
02/12/16 09:19 AM
RTS, jhmed80, engus, Rob_Pol, Nick24w
56901 Registered Users
115 registered (19kj57, akela, 87sammy, Al, 99TLC, 11 invisible), 1807 Guests and 200 Spiders online.
56901 Members
66 Forums
244602 Topics
#2691023 - 07/21/12 05:45 PM What oil for mercury mountaineer
ckmarsh Offline
Loc: ohio
I am getting a 2005 mercury mountaineer AWD 4.6L 239 hp V8
what would be a good syn oil to use for this suv it dont have a owners manual
#2691027 - 07/21/12 05:50 PM Re: What oil for mercury mountaineer [Re: ckmarsh]
Oregoonian Offline
Loc: Bend, Oregon
How about.....M-1 0w30.....or 5w30.
I believe the manual recommends 5w30...but check the oil cap....it should state the oil recommended.
03' Ford Focus SE(2.3L Duratec PZEV)/ 133K +
QSUD 0w20 / Fram 'Ultra'/ OCI: 7500 +/-
ATF: Mercon V w/Lubegard Red
#2691056 - 07/21/12 06:30 PM Re: What oil for mercury mountaineer [Re: ckmarsh]
TFB1 Offline
Loc: VA
ALL Ford 4.6L are specked or back specked for 5W-20, that said I use 5W-30 M1 EP in both of my two valve SOHC...
#2691061 - 07/21/12 06:34 PM Re: What oil for mercury mountaineer [Re: ckmarsh]
sayjac Offline
Loc: The Old North State
Son owned an 05 Explorer 4.6L, spec'd 5w20, quite certain 05 Mountaineer 4.6L does too. OLM light went off every ~5k, not a true OLM. At 5k OCI's, most any 5w20 dino will handle that. MC Syn Blend is excellent but getting relatively pricey. I'd stick with any major's 5w20, QS, PYB, VWB, GTX, or MS5K. Add a MC FL820S oil filter and you should be good to go.
If you want to use a synthetic, QSUD is the best major's everyday value at Wally.
Owner's manual pdf can be found in the link. Pick an Owners Guide edition on the right side menu.
http://owner.ford.com/servlet/ContentSer...del=Mountaineer
#2691066 - 07/21/12 06:46 PM Re: What oil for mercury mountaineer [Re: ckmarsh]
WMSmotorhead Offline
Loc: Cleveland OH USA
The factory suggestion IS Motorcraft 5w-20 on a 5000mi interval.
I use Mag1 5w-20... although the Motorcraft is good oil too. Any decent 5w-20 is good. 5w-30 if 5w-20 is not available.
#2691072 - 07/21/12 06:51 PM Re: What oil for mercury mountaineer [Re: ckmarsh]
dave1251 Online   happy
Loc: Maricopa, AZ
If you are going by the factory recommended interval just use the lowest price conventional with a motorcraft oil filter. That is what I do for the modulars that I maintain.
don't use.
#2691101 - 07/21/12 07:27 PM Re: What oil for mercury mountaineer [Re: dave1251]
ABerns Offline
Loc: Iowa
+1
#2692081 - 07/22/12 07:42 PM Re: What oil for mercury mountaineer [Re: ckmarsh]
johnsmellsalot Offline
Loc: Texas
Use Motorcraft.
1999 Buick Century 180,000 miles (first car)
2008 Chrysler PT Cruiser 70,000 miles
#2692311 - 07/22/12 10:42 PM Re: What oil for mercury mountaineer [Re: ckmarsh]
ckmarsh Offline
Loc: ohio
I get one case of any syn oil for free but it is a ford so Motorcraft should be fine just wont a good VI for winter use here in ohio.
