From what I understand, Toyota is encouraging their dealers to adopt the Toyota Express Maintenance Program. Here is more info about it:
http://toyotadriverseat.com/pr/tds/PRN-toyota-express-maintenance-transforms-202489.aspx
http://dealer-communications.com/service/convenience-good-for-your-customers-good-for-your-shop/
In my conversation with one of the advisors I know at a Toyota dealer which has gone through this change, his Level 1 techs do the minor services, basic 30k services, and other scheduled maintenance work. Level 2 techs, supposedly do tires, brakes and even timing belts!
The main shop is then reserved for warranty work and open-ended repair work and diagnostics.
In a way, this is a good thing for new techs since they have more exposure to more cars. However, this also means that if your car only sees the dealer for scheduled maintenance and normal-wear items (i.e. no repairs), the car will never see the hands of a master tech - all of the work will be done by the Express Maintenance dept.
I know that at the Toyota dealer I use most often, only their oil changes go to lube techs - everything else goes to a line tech or master tech. I guess this may soon be changing.
Thoughts on the dealership/shop environment? mechanicx?
