I have a tick/knock that occurs for the first 2 seconds only when starting a cold engine at cold temps (under 40F) that goes away after adding fuel system cleaner.
I thought it was a stuck lifter. Can a fuel system cleaner cure stuck lifters or is it something else? What else could I hearing that is now cured with a fuel system cleaner? Valve deposits?
