For a direct link:
http://img37.imageshack.us/img37/7465/1004056k.jpg
Well, I used Valvoline MaxLife 5w-30 for the first 9 months or so; maybe 7,500 miles. The car had some obvious carbon deposits in oil drains after first purchasing the vehicle. So, I used Amsoil's 'new' engine flush (the transmission and engine flush labeled product) at idle only with no load applied, for about 15 minutes prior to draining the oil twice. This increased the number of deposits initially seen in the drained oil.
I swapped over the M1 AFE 0w-30 for a 3,000 mile OCI(probably still API-SM); this is again an unknown app. I'm new to BITOG at the time and I'm uncertain with the engine(I did only just now get a valve cover removal pic, because a friend/mechanic was gathering evidence before replacing the head gasket)...
After this, I used Amsoil 0w30 SSO and got my first UOA performed w/ TBN. Insols were 'meh' higher than I liked, so I used a mix of 2 qts T6 w/ a remaining quart of AFE 0w-30 and a pint of MMO; then added another 8 ounces to top it off.
Since then, I've tried MoS2 twice; once with Amsoil AZO (my 2nd 0w-30 amsoil run; post API-SN era begin) and once with Pennzoil Ultra just prior to the current fill.
Yes, overkill I realize...oh and I tried Lubro-Moly's Pro Line engine flush. After skipping an engine flush for a bit in 2011; prior to using Pennzoil this past December. (UOA linked at the end)
The Pro Line engine flush didn't reveal any more depositing.
I've also used Amsoil's Power Foam twice on this engine for combustion chamber soaking, I've used Red Line's SI-1 fuel additive and Amsoil's Pi. Tried MMO a bit, and failed at trying TC-W3. So, it's either PEA containing or no additives for me in this app.
Now, I'm using Valvoline conventional with Lubegard's engine oil additive. I'm actually quite pleased so far, seems alright placebo is better than with MoS2.
To be fair, the car is acting really weird lately so I can't rely on placebo.
IACV probably needs to go, maybe 1 other sensor(no CEL of course go figure), but worst of all is it potentially has a head gasket and/or oil cooler leak internally mixing with the oil. My last UOA is the first I've seen confirmed coolant.
Here is the thread:
http://www.bobistheoilguy.com/forums/ubbthreads.php?ubb=showflat&Number=2655364&page=1
PS: I also can't stress enough the other maintenance areas not related to engine oil, additive, etc. This is strictly only in regards to what I put into the engine via gas tank or oil filler/air intake ingestion, etc.
