My '03 Chevy Express 3500 6.0L has 110k miles with original cooling system. Somewhere in it's life, green coolant was added. Not sure if it was compatible or not. Employees who didn't know better just added probably what was cheapest.
This past weekend I decided to drain and flush all the coolant. I removed the thermostat to give a nice flow of water to clean everything out. Couple of things I noticed..
1. With the thermostat out, the water just didn't seem to flow with much volume/pressure? How can you test if your water pump is starting to fail? It has movement, just not as hard as other cars.
2. After filling up with water and Peak cooling system cleaner, the system didn't "burp" much. I have one of those cooling system funnels that attach to your radiator and you fill and let the system burp itself. I would think there would be more air/water exchange going on.
3. I left the thermostat out to run the water/cleaner thru for a few hours and the water in the overflow tank stayed about the same. Maybe the fact that the thermostat was out filled the system more completely without many air bubbles?
Radiator fan clutch.. how can you test it?
1. When the engine is off, you can spin the fan freely.
2. When you turn it on.. the blades start to spin slowly.
3. When it gets hotter, it doesn't seem to spin much faster? I know with my other vehicle which has electric fans.. you can hear when the fans kick on.
4. Is there a way to test the fan clutch?
Thank you all for your help!!
