I've got a tecumseh 2.5hp on a motorized bike. I've been running Delo 400 15w-40 just because its what I keep around for my truck and it seemed like a good choice. The problem is, the motor doesn't have any oil smoke on startup or when its cold, but half way on my commute home in the evening when its hot, I start seeing oil smoke out the exhaust, and sometimes quite a bit. The engine is obviously pretty old and I have no idea on its history. It was headed for the trash after the owner didn't know how to clean and set the points. All I know is that it runs strong still.
Is my choice of oil a problem here? I had thought about maybe switching to a straight grade for better high temperature stability or maybe something thicker for this tired motor. I had thought about sae 50 but I'm not sure if it may be too thick? What do you all think?
