Originally Posted By: SteveSRT8
Thanks for the link. I note that it specifically states to use the molykote only on the inner sides of the shims, and not on the outside facing the piston.
See 19-21 step #8. The inner pad for the rear does not have a shim, and the arrows and wording clearly advise to advise M77 to the back of the pad itself. The original set of pads I removed from this generation TSX does have M77 on the back of the inner pad that contacts the caliper piston.
