This may or may not be something that you guys have any experience w/, but I thought Id give you a try:
Where do you feel is the most logical place to tap an oil pan for an oil return like generally. This is a custom turbo job so the return like would not be under pressure.
I just need the most unrestrictive flow from the center section of the turbo to the oil pan.
Any idea on what fitting is best and where to tap the oil pan?
Thanks,
Zachary
Thanks,
Zachary
