Assuming the old adage "you get what you pay for" does not apply, let's look at this product and how you intend to use it.
Mobilgrease 28 is a synthetic aviation grease. It's about a grade 1.5 (between an NLGI 1 and 2) that "is designed for the lubrication of plain and rolling bearings at low to high speeds, and splines, screws, worm gears, and other mechanisms where high friction reduction, low wear, and low lubricant friction losses are required". Although not the typical choice of automotive enthusiasts (especially considering the price of a new pail), it offers, at a minimum, similar performance to the baseline "EP 2" grease typically called for in your application.
The two things I would watch out for are:
a) Look at the appearance of the grease. If it still appears homogeneous as well as "smooth and buttery" (vs. hard or with a lot of oil separation), it should still be OK for use.
b) Watch for indications of incompatibility with the old grease. Typically, when incompatible greases are mixed, the dropping point (or ability to handle high temps) is reduced and the measured NLGI grade of the combined greases is reduced (say from a grade 2 to a grade 1). This will manifest itself as excessive grease running out of the application.
