I have a '99 Cobra with the T-45 manual trans, and it uses regular Dexron III/Mercon ATF, and I would prefer to use Motorcraft but all I can find is Mercon V. I have read various forums while searching this, and some people have been using Mercon V fluid in their Dexron III/Mercon-specified transmissions. Does Mercon V supercede Mercon in all applications or is it different enough that Mercon should SPECIFICALLY and only used?
