"• Some of the aluminum engines with
AFM have experienced oil consumption,
too. GM says that the oil spray that is discharged
from the AFM pressure relief
valve in the crankcase may result in carbon
deposits in the ring grooves that stick the
rings and cause oil consumption. They
have modified the rocker cover to change
the calibration for the PCV for some
applications, but the real fix is the installation
of a shield (p/n 12639759) over the
AFM relief valve to deflect the oil down
into the pan instead of allowing it to hit
the crank that throws it up on the cylinder
walls."
From this article:
http://www.enginebuildermag.com/Content/Site302/Articles/03_01_2012/986163348GMGENI_00000051561.pdf
I wouldn't hesitate to treat the engine with Auto-Rx to clean up the rings and pistons.
