Let's look at this objectively:
If you touch the hot wire from a generator that is grounded
to earth (including neutral) while standing in water; you will be shocked and possibly killed!
Under these circumstances there is a completed electrical circuit from the generator to ground through your wet feet back to the hot side of the generator!
If you do the same with an ungrounded generator; the circuit is not completed.
The above assumes there are no other connections to the generators power circuit.
Bottom line:
Avoid completing electrical circuits through your body.
Rickey.
Bottom line:
Rickey.
