Originally Posted By: Jim Allen
This is an unfortunate incident.
Exactly what oil was recommended for this engine and what does the manual say about intervals? The recommended oil is what the OLM is calibrated for, whether that's a conventional or a synthetic. If an OLM was calibrated for a synthetic, and you ran a conventional, that would be a recipe for problems. Ultimately, whatever the manual recommends is going to be what Honda will be required to live up to, not some vague recommendation from a dealer that likely can't be proven.
I have never heard of an OLM "failing" perse because it's built into the PCM. I suppose anything is possible but??? I don't know exactly how Honda's works, but most are just algorithms based on certain inputs programmed onto a chart in the PCM. There are no "sensors" in most OLMs that monitor actual oil condition. Could yours have been accidentally reset somehow partway thru the interval? Was the battery replaced during that period, the van jump started or some electrical work done?
In theory a conventional like the Mobil 5000 could run a 9K + OCI but conditions would have to be just perfect. Having live next door to NH in VT, I doubt those perfect conditions were met.
As Gabe mentioned above, a quick look in the owner's manual might have prevented this incident. It can be a hard lesson to learn, but dealer personnel can't be regarded as the end-all authority. Obviously, they should be... but reality has sharp teeth. The failsafe is an owner who knows enough to have a "bovine scatology" detector sensitive enough to set off some alarms. That requires a little self education.
Thank you, Jim. The owners manual specify's Premium Grade, API certified 5W-30 conventional motor oil for gasoline engines, but allows synthetic oil of the same grade. My dealer used 'Mobil Bulk' according to their invoices. I inquired with their parts department and was told this is the same as Mobil Super 5000 conventional oil. Mobil said that after 5000 miles it will still lubricate but the additives will begin to break down. I explained to the dealer that I was not comfortable going that long on conventional oil and he told me not to worry about it. No battery replacement, jump starting, or dead batteries.
