Originally Posted By: Hessam
I have been using Delo Syntethic, or T6 in my 96 landcruiser for about 200K now....I did have to replace one of the O2 sensors, and both the cats after about 197K on the clock, but that's more a result of old age and lots of miles, than the HDEO oil.
since i installed the new cats (ATE), I have been getting wierd cat alarms every 15K or so....when I clear the alarm, cats are fine, and then about 15K or more I get the cat alarm again (it's actually a check engine alarm, but the check engine code points to the cats being faulty...but I have taken the cat off and don't see any signs of premature wear, or excessive clogging etc....
I think HDEO's being rough on cats is more of a urban myth than anything else.
What make of cats were they? Some aftermarket cats on the market have insufficient catalyst media compared to OE, and that could cause a P0420/30 catalyst efficiency CEL code. Toyotas are picky like that. Its the ECU programming - very strict. There is another trick to shut that off tho.
