Auto-Rx: is just rinse enough?
Fayetteville, NC
I just thought of this..(i'm sorry if this is a really bad idea, but I'm just curious)
After the "rinse" phase, would it be better to do a typical "quick" engine flush to get ALL of the sludge out, or is just changing oil/filter by normal draining enough?
wouldn't more sludgy oil go out with a flush? and it's less dangerous than is normally, 'cause ARx has "liquified" the hard sludge, and there's no hard crud which can be dangerous....
has anyone thought of this?
quote:
Originally posted by Frank:
You would have already changed oil and filter draining out contaminants,sludge plain old dirt.
Any remaining third party abrasives,contaminants will drain out when rinse is finished. You also have reconditioned your seals. Your done add 3 ounces of Auto-Rx with each oil change and maintain gains and other benefits. No benefit
in adding a solvent flush type cleaner.
