Originally Posted By: Artem
I wouldn't want THAT much additives in the fuel. The required minimum gets the job done for the most part. Top Tier gas goes a step higher to insure EVEN BETTER cleanliness.
From what shell reports, its enough to keep valves spotless. Is anymore really necessary?
Top Tier is 5 times higher. It was all created by another Gov mess-up: they started to mandate the minimum, and it was 5 times lower than what was already in the gas from reputable merchants. So, all the corner cutters rejoiced: they could get away with one fifth of the norm. Imagine the savings, if you take into account the mass scale. Top Tier is nothing more than good old gas.
Although we have a sprinkle of vodka in it nowadays, and that is a whole different issue.
