Vehicle:
2006 Scion tC
Oil:
Amsoil AZO 0W30
Oil additives:
None
Make up oil added: Three (3) quarts was added total with the last half a quart added about 1,300 miles before sampling.
Engine oil capacity:
4.1
Oil filter:
TINY Mobil 1 (much smaller then the OEM filter)
Air filter:
Amsoil EA cone air filter installed halfway through the interval.
USE: Mostly highway/city @ 70/30. The wife does roughly 50 miles daily round trip to work and back and i beat on it when she gets home while i do my errands, ranking up another 50 miles or so while bouncing off the rev limiter, so the miles rack up quick.
I changed the oil because i ran out of top off AZO (i originally wanted to extend to 12k) and didn't want to add anything else in to throw off the results. I was happy with 10k anyways and wanted to see how the oil held up. I think it did very well and could have went much longer if i had the balls for it.
Code:
OIL AZO 0w30
MILES IN USE 10,217 miles
MILES 94,441
SAMPLE TAKEN 6/26/2012
Universal Average
ALUMINUM 4 3
CHROMIUM 3 0
IRON 19 15
COPPER 1 2
LEAD 1 2
TIN 2 0
MOLYBDENUM 135 83
NICKEL 0 0
MANGANESE 0 1
SILVER 0 0
TITANIUM 0 0
POTASSIUM 1 1
BORON 64 43
SILICON 22 18
SODIUM 5 40
CALCIUM 3712 2370
MAGNESIUM 17 82
PHOSPHORUS 697 712
ZINC 802 833
BARIUM 0 0
Values Should Be*
SUS VIS 210ºF 60.5 59-68
cSt @ 212ºF 10.35 9.9-12.7
FLASHPOINT ºF 425 >385
Fuel %
Antifreeze 0 0.0
WATER 0
INSOLUBLES 0.3
TBN 4.1
TAN 4.4
Lets not forget the newly installed magnetic drain plug collecting quite a bit of metallic bits. This is by far the most i've ever seen from personal experience.
I refilled with Valvoline Nextgen conventional and a Mobil 1 oil filter. Total cost for the oil change = under $10. Can't complain. Will all the recent dino vs synthetic oil debates, i wanted to try my luck with conventional oils again.
Thoughts and comments are welcomed.
2006 Scion tC
Oil:
Amsoil AZO 0W30
Oil additives:
None
4.1
Oil filter:
Air filter:
Code:
OIL AZO 0w30
MILES 94,441
Universal Average
ALUMINUM 4 3
CHROMIUM 3 0
IRON 19 15
COPPER 1 2
LEAD 1 2
TIN 2 0
MOLYBDENUM 135 83
NICKEL 0 0
MANGANESE 0 1
SILVER 0 0
TITANIUM 0 0
POTASSIUM 1 1
BORON 64 43
SILICON 22 18
SODIUM 5 40
CALCIUM 3712 2370
MAGNESIUM 17 82
PHOSPHORUS 697 712
ZINC 802 833
BARIUM 0 0
Values Should Be*
Fuel %
Antifreeze 0 0.0
WATER 0
INSOLUBLES 0.3
TBN 4.1
TAN 4.4
