Nick R,
Regardless of what oil you choose to use in your Mazda, make sure that if you are doing oil changes yourself, you create a login on mymazda.com, and record all your self services in there when you do the oil changes.
This is Mazda's own system, and if you should ever have to have a warranty claim, you just point to their own system, and tell them to pull it up using the info you put into mymazda.
You can get to it by going to the mazdausa webpage, and click on the link at the top for owners. Create a profile for your vehicle using your VIN, and you're all set to record everything you ever do to your car. Even down to tire rotations, and wiper blade changes.
BC.
BC.
