Long term protection
by whip
08/31/16 08:27 AM
Interesting article about varnish....
by demarpaint
08/31/16 08:26 AM
EPA Phase 2 might mean PC-12
by Solarent
08/31/16 07:44 AM
Is Helen ok?
by mcrn
08/31/16 07:04 AM
It's not class warfare...greyhound/
horse racing.
by Shannow
08/31/16 06:19 AM
Crossdrilled crankshafts
by FordCapriDriver
08/31/16 06:17 AM
Cryo treatment and barrier coatings? (thermal etc)
by columnshift
08/31/16 04:14 AM
Fuchs GT1 0W20XTL-16mth/7,925k
m-10 Ford Focus 2.0L
by IPCOlsenVZ
08/31/16 03:46 AM
Ravenol 0w-16 EFE
by Jetronic
08/31/16 03:33 AM
Flushing automatic transmission
by Barwich
08/31/16 03:01 AM
Does Anyone Remember...
by pscholte
08/30/16 10:21 PM
Oil filter for fuel filter?
by leroyd92
08/30/16 10:19 PM
JoeI, binarycache, MarkieB, albertson, Chevy538487
58973 Registered Users
90 registered (09_GXP, Al, 4WD, 87sammy, barkingspider, ARCOgraphite, 9 invisible), 1379 Guests and 5 Spiders online.
58973 Members
66 Forums
253802 Topics
Page 1 of 4 1 2 3 4 >
#2663167 - 06/23/12 10:46 PM My mechanic put 20w-50 in my car.
vincent714028 Offline
Loc: Alabama
It's a 94 camaro v8. A shadetree mechanic put a used engine with 160000 miles in my car. He filled it with Castrol GTX 20w-50. I think that is too thick and would like to try a thinner oil like 5w-30 since that is what is speced for my car.
I don't want to waste this oil so would it do any harm to leave it in for 3-5000 miles?
2011 Mazda 3
1994 Chevrolet Camaro Z28
#2663173 - 06/23/12 10:50 PM Re: My mechanic put 20w-50 in my car. [Re: vincent714028]
daves87rs Offline
Loc: Michigan
Can't hurt....
Whatever you are, be a good one.
#2663177 - 06/23/12 10:52 PM Re: My mechanic put 20w-50 in my car. [Re: vincent714028]
TFB1 Offline
Loc: VA
In 'bama, in the Summer, it'll be fine...
If past OCI are unknown keep a eye on the level and color of the oil, if it gets dark early, you want to consider this oil a flush and do another change in 1.5-2Kmi...
#2663183 - 06/23/12 10:56 PM Re: My mechanic put 20w-50 in my car. [Re: vincent714028]
Chris142 Offline
Loc: apple valley, ca
I'd run it a couple thousand miles then drain it. Kinda use it as a flush. 20w50 is still very popular here.
02 Wrangler Chevron 10w30
87 F250 napa 15w40
04 Tahoe super-s 5w30
Z400 Lucas 10w30
KLR250 Maxima 10w40
Can am maveric delo 5w40
#2663188 - 06/23/12 11:01 PM Re: My mechanic put 20w-50 in my car. [Re: vincent714028]
DragRace Offline
Loc: 1/4 Mile Track
No reason for that heavy of an oil in that motor,period.
#2663195 - 06/23/12 11:10 PM Re: My mechanic put 20w-50 in my car. [Re: vincent714028]
crazyoildude Online   content
Loc: New Jersey
change to a 5w30 or 10w30 before the winter
Will Not Use Oil Filters With Those Tiny Restrictive Looking Louvers! Also Not A Fan Of Oil Jugs That Don't Have A Security Inner Seal..
#2663200 - 06/23/12 11:15 PM Re: My mechanic put 20w-50 in my car. [Re: vincent714028]
deven Offline
Loc: Massachusetts
find a new mechanic
Proud user of ROYAL PURPLE products!
#2663202 - 06/23/12 11:17 PM Re: My mechanic put 20w-50 in my car. [Re: vincent714028]
JimPghPA Offline
Loc: Pittsburgh,PA U.S.A.
20W-50 in a GM 8 cylinder with 160 K miles is a good summer oil. It might cost you a little in MPG's, but with 160 K miles any XW-30 oil is probably too thin. Often when you get that kind of miles on a old GM 8 cylinder you have to use a 40 or a 50 grade as the top number.
I have Castrol GTX 20W-50 in my 1985 Olds Delts 88 with over 160 K miles on it. I had to go to something thicker than a XW-30 because it burned and leaked 30 too fast, and it would sometimes stall on a very hot day. With the 20W-50 I do not have to add oil as often, and I do not have to smell the leaking oil burning off, and it does not stall on hot days.
With that kink of miles the clearance between parts is more than it was when new, and a thicker oil works better.
I am thinking of going with something like the newer 5W-50 oil for winter. Right now with a 20W-50 in it, 15 Fahrenheit is about the coldest that I would have the temperature be and still try to start it.
Boy will I be happy when ALL vehicles on public roads are autonomous.
JimPghPa
#2663203 - 06/23/12 11:18 PM Re: My mechanic put 20w-50 in my car. [Re: vincent714028]
Lead Shoes Offline
Loc: Mn
Find a new mechanic...
The only time that motor NEEDS 20w50 is under long track sessions, but seeing as it is already in there I would run it out for a few thousand miles though, then change to 5w30.
1992 BMW 325i 183k
Castrol 0w40/Mahle
#2663209 - 06/23/12 11:23 PM Re: My mechanic put 20w-50 in my car. [Re: vincent714028]
TallPaul Offline
Loc: By Detroit
Hope he is not trying to cover up loose fitting bearings. But 20w50 should be no problem in Alabama in the summer.
#2663216 - 06/23/12 11:31 PM Re: My mechanic put 20w-50 in my car. [Re: vincent714028]
JimPghPA Offline
I would leave the 20W-50 in it all summer and think about something like Rotella T-6 5W-40 or Castrol 5W-50 for winter.
JimPghPa
#2663217 - 06/23/12 11:31 PM Re: My mechanic put 20w-50 in my car. [Re: vincent714028]
expat Offline
Loc: Canada
Ask him WHY he proberbly paid more and put in a non mainstream oil like
20 w-50?
It won't do any harm, even in Canada, I once used this oil, year round, in a Toyota truck
And got very long engine life.
But the only reason why I think he might use it, is because he suspects the engine may be an oil burner.
#2663222 - 06/23/12 11:36 PM Re: My mechanic put 20w-50 in my car. [Re: vincent714028]
LeakySeals Offline
Loc: MA
When you say specced for do you mean whats on the oil cap or dip stick? Thats a base recommended for all seasons. Take a look in your manual. What does it recommend for oil when temps are (for example) + 20 F?
Something like this?
I agree its not the best choice but it wont hurt it to leave it in and get your moneys worth. Does it burn any oil? Just blend it down topping off with some thinner oil.
02 Camry XLE 2AZ-FE 352k M1 HM 5w30 (RIP, broke pist rod 7/2/2016)
06 Escalade 135k. M1 5w30
#2663223 - 06/23/12 11:37 PM Re: My mechanic put 20w-50 in my car. [Re: vincent714028]
TallPaul Offline
Loc: By Detroit
You can drain out half the oil and save it for next OCI, then refill the half with 5w20. Will end up with somewhere in the upper end of the ballpark of 10w40.
#2663228 - 06/23/12 11:49 PM Re: My mechanic put 20w-50 in my car. [Re: TallPaul]
daves87rs Offline
Loc: Michigan
I was thinking that as well.
