My daughter uses my BMW 2006 Z4, and after purchasing tires, went to a local shop having a special on allignments. The car was overdue for a low milage oil change. Spoke to the owner who said they do a lot of BMW's and use Mobil one. They used 5w30, instead of the the 0w40 I expected. They went by an Oil data sheet that showed BMW oil 5/30 is indicated. Then they told me that the difference between the two viscosities is minimal, and that as long as I wasn't racing, there would be no concern. Should I be concerned?
RJ
RJ
