Please find specific model/type plate number and post it here online to share, otherwise: it's really hard to make guesses (there's a whole lot of different B&S in the family, you know what I mean).
(1) you mean you cleaned the carb very well, did you perform a complete teardown, dunking in carb cleaner dunking liquid, scrub clean/poke-clear all the orifices, jets, passage ways, etc compressed-air blow clear/dry of all the passageways/components, etc. and then rebuild it with a B&S carb kit? including the float? (if you are the sidedraft walbro clone types of deal, not the pulsa/vacu-jet style.)
(2) what kind of choke configuration you have on this 8hp? is it manual (level or), or auto-choke type?
(3) what kind of compression reading you getting from your engine? is the compression within range?
(4) is this a single cylinder 8hp?
(*strongly suspect that it's the carb*)
Q.
