Hello, I have a problem and not sure what is causing it. This is on a 96 Gmc truck with a 4.3 V6 engine. I start the truck up and it runs fine and as it warms up the temp gage does not stop at the usual 180-190 mark. It pushes right over to about 230 and stays there for maybe 5-10 seconds and then comes back down to 180-190 fairly quick.
This scares the bejesus out of me thinking that is is going to over heat. The water pump is only a year old and there are no leaks that I can find. It only does this as it warms up and you can drive it the rest of the day any distance and the temp gage stays steady where it always has at 180-190.
What is causing the spike in water temperature?
