Towards the middle of this video FRAM talks about collapsed center tubes caused by a "malfunctioning filter bypass valve" or a combination of both a "malfuntioning bypass valve and pressure regulator valve". And filter can blow out from malfunctioning pressure regulator valves. If you listen it's said that a malfunctioning pressure regulator will "have equal pressure in all parts of the system" and if pressure is high enough can cause filter can and gasket blow out..
And look here, http://www.fram.com/sites/default/f/uploads/en/overpressurized.pdf
Quote:
Figure 2 shows the system operating with the
regulating valve stuck in the closed position.
Pressure builds up equally on all components.
And here, http://www.fram.com/sites/default/f/uploads/en/collapsedcentertubes.pdf
Quote:
Automotive lube oil filters are designed to withstand
differential pressures significantly greater than those
experienced under normal operating conditions without
collapsing. Therefore, when an element has collapsed,
it is usually the result of a “sticky” or otherwise malfunctioning
by-pass valve.
In some instances, a “sticky” filter by-pass valve alone
is not enough to collapse a filter.
In all their material mentioning filter collapse a malfunction or sticking bypass valve is blamed. Not just the pressure regulaotr.
by-pass valve.
