Hi everyone, I'm new to this board.
Here's the product description from liqui-moly ---------------------------
MOTORCLEAN
Flushes out and cleans the engine from the inside. Highly effective cleaning additive dissolves sludge and lacquer formers, coats solid particles and liquid contaminants. These are drained with the used oil during the oil change. After carrying out this type of prepared oil change, the fresh oil is able to realise its full performance potential: ˜ The engine develops its full performance again ˜ Runs with less wear ˜ Exhaust gas properties are optimised ˜ Deficient lubrication is minimised.
Operational area: Add to the engine oil BEFORE the oil change. After approx. 10 minutes idling, drain used oil, change the filter and fill with fresh oil. 500 ml is sufficient for engi-nes holding up to 5 litres of oil.
Does this sound like something that's safe to use?
[ May 29, 2003, 02:44 PM: Message edited by: rugerman1 ]
MOTORCLEAN
