Dear All,
Please find below the results of the latest and the previous (LM Top Tec 5W-40, BMW E39 540iA, 7200 km) oil analyses for my BMW.
During this oil change interval I always used 100 % E85 fuel. The base number of the fresh oil reference of the Mobil 1 Peak Life 5W-50, by the way, is 12.00 mgKOH/g, as stated by an engineer of OELCHECK GmbH.
Based on these latest results I would assume, that 20000 km (12500 miles) should not be any problem with this oil. The reason why I added the VI improver after 12500 km was an experiment regarding the VANOS operation, whether it would improve if the oil was thicker at high temperatures ...
What are your opinions?
Philipp
Code:
REPORT #2:
Subject : Mobil 1 Peak Life 5W-50, BMW E39 540iA, 17762 km (oil), 77812 km (total)
Machine : M62B44TU (E39 540iA, YoC 2002)
Oil : Mobil 1 Peak Life 5W-50
Additive : Wynn's Oil Stop Leak (as sealant maintenance)
Additive : Liqui Moly Visco-Stabil (VI improver) (added after 12500 km usage)
Oil Usage : 4 month
Comments : [of the engineer performing the analyses]
The values of wear are within normal range.
The base number BN is slightly lower compared to the fresh oil reference.
All other values are within normal or expected range.
REPORT #1:
Subject : LM Top Tec 5W-40, BMW E39 540iA, 7200 km (oil), 60050 km (total)
Oil : Liqui Moly Top Tec 4100 5W-40
Oil Usage : 5 month
The values of wear metals have risen only slightly.
This low wear is within the normal range.
The values of additives differ from the values of the fresh oil reference in our database.
The fuel content is negligible and is below the detection limit.
REPORT #2 #1
CURRENT PREVIOUS
WEAR
Iron Fe mg/kg 17 15
Chromium Cr mg/kg 0 1
Tin Sn mg/kg 0 2
Aluminium Al mg/kg 3 3
Nickel Ni mg/kg 0 0
Copper Cu mg/kg 13 6
Lead Pb mg/kg 3 3
Manganese Mn mg/kg - 1
PQ-Index - 26 OK
CONTAMINATION
Silicon Si mg/kg 10 15
Potassium K mg/kg 2 1
Sodium Na mg/kg 7 0
Water % < 0.10 < 0.10
IR-Glykol - negativ negativ
Fuel % < 0.30 < 0.30
OIL CONDITION
Viscosity @ 40°C mm²/s 110.95 80.50
Viscosity @ 100°C mm²/s 16.90 13.43
Viscosity Index - 166 170
Oxidation A/cm 11 18
Nitration A/cm 9 8
Sulfation A/cm 5 9
Dispersing Power % 97 92
ADDITIVES
Calzium Ca mg/kg 2703 2179
Magnesium Mg mg/kg 94 249
Boron B mg/kg 34 32
Zinc Zn mg/kg 1072 1009
Phosphorus P mg/kg 821 826
Barium Ba mg/kg 0 0
Molybdenum Mo mg/kg 61 2
Sulfur S mg/kg 2482 3420
ADDITIONAL TESTS
BN mgKOH/g 8.00 7.27
Philipp
Code:
REPORT #2:
Oil Usage : 4 month
REPORT #1:
Oil Usage : 5 month
REPORT #2 #1
CURRENT PREVIOUS
WEAR
Iron Fe mg/kg 17 15
Tin Sn mg/kg 0 2
Nickel Ni mg/kg 0 0
Lead Pb mg/kg 3 3
PQ-Index - 26 OK
CONTAMINATION
Sodium Na mg/kg 7 0
OIL CONDITION
Nitration A/cm 9 8
Sulfation A/cm 5 9
ADDITIVES
Boron B mg/kg 34 32
Barium Ba mg/kg 0 0
ADDITIONAL TESTS
