Mazda Type-FZ Fluid & Skyactiv Drain/Refill Tips
by The Critic
05/02/16 03:13 AM
Meguiars Whole Car Air Re-fresher
by The Critic
05/02/16 02:10 AM
Costco Tire Service - now available for all tires
by The Critic
05/02/16 01:57 AM
Selling fresh Australian air in a can to China
by HTSS_TR
05/02/16 01:55 AM
MC FL-820S C&P Coming
by BlueOvalFitter
05/02/16 12:11 AM
Creeping and Thickening
by camrydriver111
05/01/16 11:53 PM
Ariens B&S 17.5 o/c w/MK additive
by urrlord
05/01/16 11:31 PM
Question about grease for exmark mower
by Jetstreamz06
05/01/16 10:27 PM
Grease on door seals and glass
by JHZR2
05/01/16 10:12 PM
15k miles on Fram xg6607 2011 Mazda 2
by micmac
05/01/16 09:53 PM
2001 Mazda Tribute atf
by urrlord
05/01/16 09:43 PM
Bought a 21..95 Lawnmower battery at O'Reiily's
by andyd
05/01/16 09:20 PM
stydel311, jackadf, rlb4, apenland01, 2ManyMiles
57767 Registered Users
15 registered (Boczech, EchoTech1945, bbhero, FFeng7, Falcon_LS, alcyon, 2 invisible), 500 Guests and 315 Spiders online.
57767 Members
66 Forums
248342 Topics
#2652359 - 06/12/12 06:08 PM Some TR-6060 questions.
blmlozz Offline
Loc: VA
Hey there fellow BITOGers.. I'm finnaly back into a 6MT vehicle.
In this case it's attached to an LSA in a CTS-V.
Even though I have a general idea of what I'm going to do for OCI's and oil choice after a few hours of searching I still have a few questions;
concerning the TR6060;
1) I know that any Universal ATF is generally recomended for this trans, and some even go with syncromesh or an acutal gear oil.
I was partial to some Mobil 1 ATF myself(for warranty reasons mostly, but it's also available locally) however I have concerns about using this since the specification for this trans very specifically states Dexron III. It was designed during a time that Dexron VI was avaliable so I have to wonder if there's an actual reason that this was specifically required. Anyone know if My assumptions have grounds? On the one hand I want to use the right product, but on the other hand, Dex III is an obsolete specification, so the *only* oil that's going to be compliant is NOS that's a couple of years old..
2) about when should I change the factory fill oil?
#2652375 - 06/12/12 06:17 PM Re: Some TR-6060 questions. [Re: blmlozz]
Corvette Owner Offline
Loc: Waldorf, Maryland
What year is your car? I use Amsoil Torque Drive ATF in my 1998 Corvette 6 speed. Up until 2001, these transmissions used paper blocker rings and you could NOT use Mobil 1 ATF in them.
I tried Mobil 1 ATF but had problems after 50,000 miles and switched to Amsoil, which immediately solved my problems.
I would change at 50,000-60,000 miles.
Edited by Corvette Owner (06/12/12 06:30 PM)
Vehicles:
98 Corvette
06 Murano
96 Chevy Van (Custom Conversion)
14 Chevy Impala
10 Starcraft Boat
13 Buick Enclave
#2652442 - 06/12/12 07:08 PM Re: Some TR-6060 questions. [Re: blmlozz]
blmlozz Offline
Loc: VA
I had read that as well, and that they since went to Carbon fiber Blocker rings so people have *assumed* it's OK to use Mercon V type ATF fluid.
it's a 2012 model year with an april build date.
really? I was thinking 5,000 miles.
The severe service schedule trans oil change for the CTS-V is 25K, and I'm sure between my every day driving and autocross/VIR/MIR sessions I qualify for that.
50K on the single OCI or just 50K worth of OCI's?
Edited by blmlozz (06/12/12 07:09 PM)
#2652450 - 06/12/12 07:12 PM Re: Some TR-6060 questions. [Re: blmlozz]
The shop manual never calls for change of trans fluid ! It was one OCI of 50,000 miles.
Vehicles:
98 Corvette
06 Murano
14 Chevy Impala
10 Starcraft Boat
13 Buick Enclave
#2652454 - 06/12/12 07:18 PM Re: Some TR-6060 questions. [Re: Corvette Owner]
blmlozz Offline
Loc: VA
ahh yes, the infamous lifetime fill.
Edited by blmlozz (06/12/12 07:22 PM)
#2653316 - 06/13/12 04:29 PM Re: Some TR-6060 questions. [Re: blmlozz]
dailydriver Offline
Loc: Bucks County, Pa.
I would NOT EVER, NEVER use a Dexron 6 fluid in a Tremec manual gearbox!!!! no-no
It is WAAAAYYYY TOO THIN!!
There is a reason it is NOT 'backdated' for the manual gearboexes the way it is for the slushboxes which previously used the Dex 3. wink
If you are worried about warranties I would just go with the Mobil 1 (you can always tell the dealer that plain old mineral based Dex 3 labelled/specced fluid is LONG GONE!).
If not RL D4, or Amsoil's ATF (or Torque Drive, as Corvette Owner has suggested) are both EXCELLENT choices!
If you are REALLY beating on this gearbox for LONG open-track sessions in high heat, some would suggest RL's MTL, or Amsoil's MTF (or a 50/50 mix of those and their equivalent company's ATFs).
I would NEVER put an actual (labelled) gear oil in a street Tremec gearbox! (WAAAYYY TOO THICK! Besides the compounds in a GL-5 fluid eating up the blocker rings/adhesives for such in a T56/TR-6060 no matter WHAT materials they are made of!!)
2000 Z28 1SC 6 speed 180K miles
4L Motul 300V 0W-40, 2L Motul 300V 0W-20
M1-206 oil filter
Motul Gear 300 75W-90
Red Line D4/MTL in the T56
#2654221 - 06/14/12 01:38 PM Re: Some TR-6060 questions. [Re: blmlozz]
mechtech2 Offline
Loc: Chicago Area
Are you saying that a new 2012 vehicle specs fluid that is no longer made?
#2654681 - 06/14/12 10:11 PM Re: Some TR-6060 questions. [Re: mechtech2]
MrHorspwer Offline
Loc: Michigan
Dexron 3 is still made... it's just no longer called Dexron 3. The *offical* new GM part name is "Manual Transmission Fluid". The GM P/N is 88861800.
#2654909 - 06/15/12 09:14 AM Re: Some TR-6060 questions. [Re: blmlozz]
NateDN10 Offline
Loc: Rochester, NY
Does the manual actually call out Dexron 3 specifically? That would be very strange, since it's been an obsolete specification for several years.
For warranty concerns, stick with GM manual transmission fluid, as MrHorspwer posted. Aside from warranty, Mobil1 ATF (or really any Dex/Merc ATF) will work. Royal Purple also has a "Synchromax" product with ATF viscosity but a gear oil additive package.
2005 Chevrolet Cobalt - 95,000 mi.
2012 Mazda5 - 80,000 mi.
#2655103 - 06/15/12 01:03 PM Re: Some TR-6060 questions. [Re: NateDN10]
blmlozz Offline
Loc: VA
It does not call for Dexron III specifically, It just calls for the GM Part number. Even the bottle doesn't say Dexron III, It calls itself GM manual transmission and transfer case fluid or similar.
Originally Posted By: 2012 CTS-V users manual
Manual Transmission (CTS-V) Manual Transmission Fluid (GM Part No. 88861800, in Canada 88861801
The only reason we know it's Dexron III is;
we know it comes FF with Texaco Dex III, and I believe other vette users manuals acutally quote Dex III back before the license expired.
Thanks for all the suggestions everyone, I would be curious about the differences between the mercon V M1 ATF specification/fomula and the Dexron III Specification. Someone mentioned VI is too thin and thus why it was not backwards compatible with MT Dexron III requirements. My retort to that would be, has anyone done VOA's on the GM part number oil and M1 ATF to see if there are substantial differences in these oils? I'm thinking what may be useable may not necessary be better.
Edited by blmlozz (06/15/12 01:13 PM)
#2655116 - 06/15/12 01:16 PM Re: Some TR-6060 questions. [Re: blmlozz]
blmlozz Offline
Loc: VA
acutally.. through some searching
http://www.bobistheoilguy.com/forums/ubbthreads.php?ubb=showflat&Number=1614231
and it does sort of confirm my concerns. There's more than twice the boron, phosphorous and calcium in m1 ATF versus the GM stuff, but at least the visc is the same. Now I just need to remember if any of these elements can cause harm in the 6060's internals.
The other thing too--- what's a good FF oil drain intervale? I would imagine it should be longer than an engine or diff since there's a lot of moving parts trying to wear in. Does 5,000 sound acceptable? Thanks again.
Edited by blmlozz (06/15/12 01:22 PM)
