Detroit Series 60 14.0L (No EGR) 600 bhp / 1950lb-ft
Rotella T3 15W40 + Rotella Triple Protection Add Oil
Capacity: 10 gallons (Rotella T3 15W40)
Add Oil: 4 gallons (Rotella Triple Protection 15W40) Has consumed about 1 qt every 4000-5000 miles since new.
Now also has small leak at rear. Will repair at clutch replacement time.
Code:
Unit Miles - 760,834
Lube Miles/Time - 44,194 Miles / 841.8 hours
Lube Duration - 3.5 Months
Fuel - 5,595 gallons (7.9 mpg)
Full Flow Filter - Donaldson P552100 (44,194 Miles / 841.8 hours)
Bypass Filter - NONE
16 - Iron
1 - Chromium
0 - Nickel
1 - Aluminum
2 - Copper
14 - Lead
0 - Tin
0 - Cadmium
0 - Silver
0 - Vanadium
7 - Silicon
4 - Sodium
0 - Potassium
0 - Titanium
34 - Molybdenum
0 - Antimony
0 - Manganese
0 - Lithium
9 - Boron
831 - Magnesium
1379 - Calcium
0 - Barium
1138 - Phosphorous
1425 - Zinc
13.9 - Viscosity 100 °C cSt
5.00 - Base Number mg KOH/g (D4739)
16 - Oxidation abs/cm
10 - Nitration abs/cm
Code:
16 - Iron
1 - Chromium
0 - Nickel
1 - Aluminum
2 - Copper
14 - Lead
0 - Tin
0 - Cadmium
0 - Silver
0 - Vanadium
7 - Silicon
4 - Sodium
0 - Potassium
0 - Titanium
34 - Molybdenum
0 - Antimony
0 - Manganese
0 - Lithium
9 - Boron
831 - Magnesium
1379 - Calcium
0 - Barium
1138 - Phosphorous
1425 - Zinc
