Originally Posted By: 4ever4d
In my mind i can see the point of a thread end bypass being better as pertaining to backwash contaminates, but with a loss of media surface it may not be ideal or a good trade off as the filtering ability may suffer.
I suppose it matters when one looks at the size of the filter in the first place. Bill has some pics in this oil filter forum comparing a small Wix (like I use) to a small Purolator, I believe, the former having the thread end bypass and the latter having the dome end bypass. In a small filter, it makes a significant difference. For my application, I use Wix because of availability, but Bosch is my preference due to its price being about half that of the Wix, and has the dome end and correspondingly larger filtering area, but I must order them online.
In comparing a thread end 51515 or FL1A to a base end equivalent, I doubt it would make as much of a difference. Over the years, I've owned a lot of Fords and tend to stick with thread end bypass simply due to my usage of Motorcraft and Wix (most of which are thread end, but not all).
In any case, it might matter if one is loading up the filter in the first place. Under conservative OCIs, will it make a difference?
