Originally Posted By: martinq
A Dexron VI certified fluid just means it meets the more stringent shear, viscosity, volitility and friction specs above / beyond that of Dexron III.
For an automatic transmission, I 100% agree.
Either way, I would always trust a DexVI fluid over a too-thick or high-shear DexIII.
This was my thinking at first. However, for some reason, Toyota doesn't trust Dex VI fluid in its PS systems. My van is a 2008, well after the 2005 introduction of Dex VI, and both the cap and the owners manual still explicitly spec only Dex III fluid for the power steering. Could Toyota just be dragging its feet on specifying a newer fluid that could work just as well? Possibly. I decided to play it safe and use the fluid that they recommend.
