Truck Odometer: 199300 mi
Miles on oil: 12000
4 quarts of makeup oil added since last oil change.
From Polaris Labs.
Wear Metals:
Iron; 41 ppm
Chromium; 3
Al; 4
Copper; 4
Lead; 1
Contaminants:
Silicon; 8
Sodium; 11
Multi-source metals:
Moly; 66
Boron; 41
Additive metals:
Mag; 1162
Calcium; 1053
Phos; 1136
Zinc; 1377
Fuel Dilution Soot Water
KV100 = 14.2 cSt
TBN = 6.7
Oxidation = 12
Nitration = 8
Polaris Comments: Data indicates no abnormal findings. Resample at normal interval.
This is surprisingly good, considering that 6000 of the 12000 miles on the oil was towing. I expected much higher soot owing to the hard running. Maybe I'm not running it as hard as I have been thinking. And since I have been feeding the engine a steady diet of fuel blended with 10% waste oil, I expected the TBN to be much lower. TBN starts out at 10.6 for RT6, and it's only down to 6.7, which is only 45% used up.
KV100 tests right at the value that's on the TDS, so it's not been shearing.
It seems like I should be able to extend this OCI, but how much? Sample again in 6000 miles, and see how things look then?
Miles on oil: 12000
From Polaris Labs.
Wear Metals:
Iron; 41 ppm
Chromium; 3
Al; 4
Copper; 4
Lead; 1
Contaminants:
Silicon; 8
Sodium; 11
Moly; 66
Boron; 41
Additive metals:
Mag; 1162
Calcium; 1053
Phos; 1136
Zinc; 1377
KV100 = 14.2 cSt
TBN = 6.7
Oxidation = 12
Nitration = 8
