My dads 2002 truck with the 5.3L burns and leaks about 1 quart per 1200 miles. I typically give it 5w-30 PYB. Seeing as how nothing is on the driveway even though the rear main seal is going bad, I assume it burns off more than leaks (never any blue smoke out the back though). I've tried Pennzoil High Mileage oil before and it never makes a difference.
Would moving to a thicker oil like 5w-40 or 10w-40 help it or is it not worth the risk of the thicker oil? It's coming up for it's next oil change and I can get some regular Castrol 10w-40 for pretty cheap on clearance at a local store.
