Originally Posted By: 1 FMF
http://www.aircondition.com/tech/questions/82/
for any r134a system in a car, with engine running and AC on you should see at least 1.5 times the ambient air temp in Fahrenheit over 60F, generally it's around 2x. So for an 80F day you should see over 120psi, generally up around 160-200 psi and the high side will go up and down as the radiator fans kick on and off and heat builds up in the high side of the AC system.
low pressure side is around 30-40 psi. when the ac system engages if the low pressure side goes down below 30 psi then you are most likely low in refrigerant. The low pressure switch generally turns the ac compressor off at 20-25 psi. If the compressor runs for a very short time, shuts off, then turns back on again in 30 seconds then you are most likely low on refig. and the low presure switch is working as it should.
on your honda or toyota they will have a TX valve as opposed to a fixed orifice tube which is common on GM. if you know you have the correct amount of refrigerant in the system and are getting very low side pressures and the system shuts off that can be due to a sticking TX valve. they are around $50.
A common cause for loss of refrigerant is the valves in the high and low side ports where you connect your gauges, try loosing then re-tightening them with a valve tool.
there is no good way checking for correct amount of refrig. in the system since pressure varies with temperature. You can refer to pressure-temperature charts to get you close and that's fine most of the time, but the best way is by evacuating the system and charging by weight. the system is tolerant to usually +/- 2 ounces of r134a. So if it requires 1.5 lbs of r134a, then anything outside of 22-26 ounces becomes a problem. and that +/- 2 oz is a % based on system capacity, for a system requiring less say 1.0 lb then the tolerance is closer to +/- 1 ounce, and vice versa.
here is some more info, see faqs or tech
http://www.autoacsystems.com/
+1
Quote:
this is for your 97 toyota avalon correct?
you're either low on refrigerant or have a bad thermostatic expansion valve, known as TEV or TX valve. I believe these are more tolerant to overcharging than an orifice tube system, so you can add an 8 oz can of r134a and see what that does, worst case you get higher compressor head pressure (and lower efficiency) and you'll see that on your high side gauge but the TEV should regulate and give you cold consistent evaporator temps. If one 8 ounce can doesn't help then it's the TEV which is common. If you haven't touched it since the repair there's probably a leak, I would loosen then retighten in the valves in the ports. if they have plastic caps, listen for a little pssst when you undo them if so they are seeping and after a month it will be low and not blow cold.
+2
This is excellent advice.
