This is the second sample that was tested for this engine. There was also a short run of Synpower 5w30 in between the two that wasn't tested since it won't be used again. The 0w40 did a great job as far as I can tell. Nickel is kind of odd but I don't know what that might indicate. Silicon was amazing again at 3, but the intake system is a work of art on this thing so maybe not that surprising. CBS indicated 4,500 miles left when it was changed.
Comments: Good call on letting us know about the Valvoline; we did find some residual sodium in this sample, and if you hadn't mentioned it, we probably would have at least raised the possibility of coolant. Since we know where this sodium came from though, we can cross that worry off the list. We're not sure where nickel is coming from in this engine, but it's a fairly unusual find. With everything else looking so good, it's hard to call it a major problem, but check back to monitor. The TBN was still good, at 3.3, so try 16K-17K miles again, or let the CBS guide you. Nice engine!
Code:
Oil M1 0w40 VV 5w30 BMW 5w30
MI/HR on Oil 14,828 7,832 16,817
MI/HR on Unit 85,526 70,698 62,866
Sample Date 4/2/12 9/27/11 6/24/11
Make Up Oil 0.5 0 0 AVERAGES
ALUMINUM 3 NT 5 5
CHROMIUM 0 NT 0 0
IRON 9 NT 15 15
COPPER 2 NT 4 5
LEAD 0 NT 1 2
TIN 2 NT 0 1
MOLYBDENUM 80 NT 181 127
NICKEL 8 NT 4 0
MANGANESE 1 NT 5 3
SILVER 0 NT 0 0
TITANIUM 0 NT 0 0
POTASSIUM 3 NT 0 4
BORON 94 NT 60 51
SILICON 3 NT 4 6
SODIUM 50 NT 15 9
CALCIUM 2862 NT 2366 2232
MAGNESIUM 14 NT 19 156
PHOSPHORUS 810 NT 903 828
ZINC 951 NT 1286 1023
BARIUM 0 NT 0 0
PROPERTIES
SUS Viscosity @ 210°F 69.7 NT 72.0
cSt Viscosity @ 100°C 12.88 NT 13.5
Flashpoint in °F 400 NT 370
Fuel %
Antifreeze % 0.0 NT 0.0
Water % 0.0 NT 0.0
Insolubles % 0.1 NT 0.2
TBN 3.3 NT 2.1
Code:
ALUMINUM 3 NT 5 5
CHROMIUM 0 NT 0 0
IRON 9 NT 15 15
COPPER 2 NT 4 5
LEAD 0 NT 1 2
TIN 2 NT 0 1
NICKEL 8 NT 4 0
MANGANESE 1 NT 5 3
SILVER 0 NT 0 0
TITANIUM 0 NT 0 0
POTASSIUM 3 NT 0 4
BORON 94 NT 60 51
SILICON 3 NT 4 6
SODIUM 50 NT 15 9
BARIUM 0 NT 0 0
PROPERTIES
Fuel %
Water % 0.0 NT 0.0
TBN 3.3 NT 2.1
