Replacing vacuum breaker off external faucet
by Vikas
07/27/16 05:55 PM
Mobil1 EP 5W20 in Honda Accord
by alanwayne1908
07/27/16 05:46 PM
Grey color when wiping dipstick on VW VR6
by Guitarman200806
07/27/16 05:13 PM
Any audio gear junkies here?
by BeerCan
07/27/16 03:45 PM
FRAM XG7317 Cut Open After Street and HPDE Use
by HX520W
07/27/16 03:05 PM
Emergency declared on 2 California wildfires
by HTSS_TR
07/27/16 02:46 PM
Scratched interior plastic woodgrain trim
by TmanP
07/27/16 02:32 PM
Kia Sedona oil leak
by surfbum
07/27/16 02:19 PM
Castrol Australia's take on the issue with Zddp
by FordCapriDriver
07/27/16 02:09 PM
A Car Dear to my Heart - Gordon Murray F1 Designer
by HTSS_TR
07/27/16 02:08 PM
Need clarification regarding toe alignment.
by ST2008
07/27/16 02:04 PM
Engine Oil in Crusader Engines
by carverguy11
07/27/16 01:30 PM
uicgrad, snydercn, surfbum, Tmemz4, woollum86
58613 Registered Users
97 registered (alanwayne1908, 2165, 2009Edge, 97prizm, 2015_PSD, 9 invisible), 1855 Guests and 13 Spiders online.
58613 Members
66 Forums
252327 Topics
Page 1 of 2 1 2 >
#1944845 - 07/06/10 11:05 PM Oil pumps that suck through the dipstick tube?
wannafbody Offline
Loc: PA
Does anyone own one and does it work and is it worth buying?
2000 TA WS6
#1944879 - 07/06/10 11:53 PM Re: Oil pumps that suck through the dipstick tube? [Re: wannafbody]
HTSS_TR Online   content
Loc: Lake Forest, CA
I used Mityvac Fluid Evacuator MV7201 for about 6 years, it works very good on the E430 because the engine was design to suck the oil from the engine with such a device, someone in MB forums tested it with standard drain plug and found that it suck out more oil.
It works on the LS400 and S2000 but with several trials, I mean it does work but I had to adjust the suction tube several times to be able to get most(90-95% or more) oil out.
For newer European engines, Mityvac Fluid Evacuator MV7201 is the best tool to do oil change, it costs about $70-75 at Amazon and it worth every penny.
'00 MB E430
'04 Honda S2000
'06 Volvo V70
'14 Honda Accord LX
"Throwing food away is like stealing it from the poor and hungry" Pope Francis
#1944908 - 07/07/10 12:46 AM Re: Oil pumps that suck through the dipstick tube? [Re: wannafbody]
UncleS2 Offline
Loc: Far North East Texas
CAVEAT: Some engines have dipstick tubes that won't allow tubing to be inserted into the crankcase. (Usually because of sharp bends). If you have doubts about yours- I'd say go to your local hardware store and get a few feet of the white, semi-stiff small diameter(a bit less than 1/4" OD- eyeball your dipstick tube first) & try pushing it down the tube.
CAVEAT II: The model I have is *NOT* to be used for gasoline or other volatile fuels or liquids. I think this includes diesel fuel too, but not 100% sure. This holds for all the plastic Mityvac models, IIRC.
I recently bought a Mityvac 7400. Link: http://www.amazon.com/Mityvac-7400-Liter-Fluid-Evacuator/dp/B000JFJM14/ref=pd_sbs_sg_2
I had to buy some additional tubing, from my local Ace Hardware- the included tubes were too short for the unit to stand on the floor, reach up over the side & then go all the way down the dtrans fill/dipstick tube- but now I can pull fluid from my brakes, automatic transmission(reason I bought it), power steering, rear end, cooling system(radiator, expansion tank, could even push a hose down into a heater or radiator hose!), as well as engine oil(but will probably keep using the drain plug for that, gotta change the filter anyway).
Does it work? So far, I've used it for transmission, power steering, and brake fluid- yes sir, it's great! thumbsup
Is it worth it? I dunno- only you can answer that. Does your car present a difficult oil drain? How about lawn mowers, 4-wheelers, etc? These days, Mercedes shops don't drain oil from Mercedes cars, they draw it out through the dipstick tube! But like I said above- didn't buy it for motor oil.(but you know I'm gonna have to try it out! grin)
I answered it for myself like this- what could I get anyone to do to my auto trans for $54? Answer- pretty well nothing- and I *still* wouldn't be able to siphon out 3-4 qts of trans fluid at home, even after they had my $54! So I chose to spend my $$ toward auto maintenance independence. Your decision may vary.
The Emperor Has No Clothes.
Pay no attention to that man behind the curtain.
Sad to say, Bob, Terry, & Johnny were 100% right.
#1944912 - 07/07/10 12:51 AM Re: Oil pumps that suck through the dipstick tube? [Re: UncleS2]
meangreen01 Offline
Loc: WI
http://www.northerntool.com/shop/tools/product_390306_390306
Have had this for about 6 mo. Low tech. Wish it had a transparent window with liquid measure scale on it, but has done a good job so far.
Also it's less expensive if bought in store...
01 Durango 4.7 4x4 ----- Citgo Semi-Syn/Puro Classic
98 Contour SVT --------- PP/FL-820s
06 Mazda6s -- M1 0w-20/FL-820s
#1952126 - 07/13/10 05:01 PM Re: Oil pumps that suck through the dipstick tube? [Re: meangreen01]
Spector Online   content
Loc: Chattanooga, TN
i also have the Mityvac 7201 that both extracts and pumps in fluids. had it about 5 or mroe years also and love it. Good for any reservoir or in one case when the washing machine would not pump out the water it also worked fine.
#1953666 - 07/15/10 01:36 AM Re: Oil pumps that suck through the dipstick tube? [Re: Spector]
severach Offline
Loc: MI or LA
There's no reason to believe that the dipstick tube would point to the lowest spot in the sump so draining the oil this way may leave more old oil in the system. Other than boats I find the drain plug to be much too easy to try to improve on it.
I use one of these pumps to pull the transmission fluid out before dropping the pan. Changing the ATF is a lot easier and cleaner when the risk of boiling oil on the troops is gone.
#1953720 - 07/15/10 04:59 AM Re: Oil pumps that suck through the dipstick tube? [Re: HTSS_TR]
ludey Offline
Loc: California, USA
Re:
I heard it works well with German vehicles but terrible on Japanese Imports. I am not sure about Domestics. It works well on 2008 Mercedes S550 and just tested it out on my 2009 Honda Odyssey. It clears all 10qts in Mercedes with no problems. My Odyssey is a different story. It took in only 2.5qts out of 4.5qts.
#1955533 - 07/16/10 03:16 PM Re: Oil pumps that suck through the dipstick tube? [Re: severach]
Believe it, the oil dipstick tube would point to the lowest spot in the sump of most if not all Mercedes sine mid 1990's and many other German engines. Someone in a MB forum did the test, he first used the oil extractor to vacuum the oil via dipstick tube then removed the drain plug and found no oil dripped out of the drain hole.
Asian and American engines are different story.
'00 MB E430
'04 Honda S2000
'06 Volvo V70
'14 Honda Accord LX
#1956741 - 07/17/10 04:24 PM Re: Oil pumps that suck through the dipstick tube? [Re: HTSS_TR]
joel95ex Offline
Loc: texas
I bought a liquivac and love it.
95 Accord 4cyl Vtec. 500,000+miles
Supertech,PYB,PP, purolator, wix, fram
2013 sonata 65k miles
PP, QSUD,10w-30 oem filter
#2045679 - 10/13/10 03:10 PM Re: Oil pumps that suck through the dipstick tube? [Re: wannafbody]
ahoier Offline
Loc: Cocoa, FL
walmart sells a "siphon pump" that has the "Pennzoil" name on it, but it's actually made by "another" company if you read the back of the package.....anyone tried anything like that?
My local WM actually sells 2, they have the "classic" bulb/siphon type, and a "Multi-Purpose" Siphon/Pump that says it can be used for siphoning "any" fluid, or even as a pump to pump up inflatables....
Actually, here's the one:
Pennzoil Multi-use Hand Pump @ Northern Tool
Frp, readiong the package, you prime it a couple times, and then the fluid will simply flow to the "lower" container (oil drain pan)
Then, next to that one at Walmart, they had the "regular"/classic bulb siphon siphon bulb cheapo thing
Only, with the Pennzoil name on it :p
Anyone tried something like these for siphoning OIL though? I could understand gas, coolant, etc.........but would think oil would likely be too "thick" to travel up the pump and down into the draining pan......?
And how would that "fare" with hot oil? I'm assuming you couldn't use either of these pumps with a "warmed up" engine....?
Any experience?
I got about 500 miles on my current OCI and was contemplating getting an oil sample, but don't really want to have to "change" (completely drain) the oil yet....and was thinking about trying one of these pumps (the "MultiPurpose" pump is 10$ at WM, the "siphon" is only 4$ so no real loss if it didn't work heh). On the flipside, these are a lot cheaper than the Blackstone pump....though I did notice the Blackstone pump is aluminum....the 10$ Pennzoil pump "appears" to just be plastic....and based on the construction, I can't tell if the oil would "reach" or otherwise "contaminate" the actual "pump"....
#2045728 - 10/13/10 03:34 PM Re: Oil pumps that suck through the dipstick tube? [Re: ahoier]
mgm13 Offline
Loc: Rio Grande Valley
Mity-Vac I've done cooling systems,transmissions and motor oil changes with ease. Can't beat it.
mgm13,NRA Life Member
2012 Toyota Highlander LTD
#2050445 - 10/18/10 02:11 PM Re: Oil pumps that suck through the dipstick tube? [Re: ahoier]
Spyder7 Offline
Loc: NL, Canada
Any experience?
I think there must be at least two dozen versions of that identical pump, in the identical package, with only the cardboard insert varying to brand it by whoever is importing it.
I used it for my last OC, for two reasons: my base pan and plug were stripped by a quick lube, and I prefer to leave the self tapper in there now right where it is until I eventually replace the pan; and due to that, I wanted to see if it was feasible to use the dipstick hole for OCs without committing the money before hand to something like a Mityvac.
To that end, it served its purpose, and I know I can leave the pan as it is and do an effective OC through the dipstick hole on this car. That said, I won't be doing another oil change with that hand pump - next time it'll be with something like a Mityvac or equivalent.
It got the oil out, but it took forever to do it, and one of the hoses managed to separate part way through making a nice mess.
As proof of concept, to see if the dipstick hole is feasible in your car to do an OC through, it'll do. But once you've tried it once you won't want to use it again.
-Spyder
2000 Corolla VE 118K km
Syntec 5W30 & QS filter
#2050548 - 10/18/10 03:48 PM Re: Oil pumps that suck through the dipstick tube? [Re: wannafbody]
Donald Online   content
Loc: Upstate NY
Look at the BoatUS catalog, those kind of pumps are very common when changing oil in a boat.
2015 Ford F250 w/Powerstroke
2001 Jeep Grand Cherokee Laredo 4.0- sold
1999 Dodge Ram 2500 w/Cummins- 4-sale
#2644405 - 06/04/12 05:01 AM Re: Oil pumps that suck through the dipstick tube? [Re: wannafbody]
VicMatson Offline
Loc: Baltmore, Maryland
I know this is an old thread, but does anyone know if the Walmart pump will work with coolant by inserting the "dipstick" in the radiator?
#2644616 - 06/04/12 10:45 AM Re: Oil pumps that suck through the dipstick tube? [Re: wannafbody]
97 GTP Offline
Loc: LI, NY
I tried one of those hand pumps and quickly threw it in the garbage. I then saw one of those "top siders" and thought.... so I built this....
http://www.clubgp.com/newforum/tm.asp?m=2130513
Page 1 of 2 1 2 >
