If you are willing to go used, consider the JD jx75 or the sb, se line. I bought a 1998 JD jx75 recently from the original owner. It wouldn't start this spring so he bought a high wheel Husqvarna, and put the JD up for sale. I got it for $70, brought it home, cleaned the carb and fuel system and it started on the first pull. This mower sold for almost $800 in 1998! It has the Kawasaki 150v 5.5 hp engine, a tuff torque 5 speed transmission, ball bearing wheels, blade brake clutch, bagger and mulch plug. An oil filter setup is available from JD for about $60 if you want, and the engine is fully pressurized with or without the filter setup. I also have a JD sb14 whch is basically the same mower, but the jx is green and the sb is natural aluminum. Both have aluminum decks yet weigh 100 lbs! For the price of a basic push mower at wal-mart you can have one of the best mowers ever made if you are willing to buy used....just my 02 of course. Thanks, G-man
