Originally Posted By: Gebo
I inadvertently sprayed window cleaner on my clear plastic instrument panel. It left a few cloudy spots. Is there a way I can remove those cloudy looking spots?
Did you use automotive, ammonia-free? I've never intentionally used it to clean clear plastic, but having some accidental over-spray never seemed to cause any issues.
FWIW, I wasn't trying to beat you about the brow if it was household glass cleaner that you used. I'm curious to know whether the automotive-use, ammonia-free glass cleaner, if that's what you did use, affects plastic. If so, I'll need to be a lot more careful - I kind of just spray away with out regard for collateral damage. Ha
I agree. If it was an ammonia based cleaner (windex for example) it can cause problems on automotive plastic and windows. It has been known to cloud plastic and break down the glue on any form of tint. As mentioned above, plasticx will work and in the future I would use a slightly damp microfiber and a dry one to clean the plastic. Works wonders and as cheap as a splash of water.
