Maximum1966 -
if your vehicle is still in warranty, and/or you want Wix to cover any potential issues, you'd need to use the spec'd fitler.
If warranty coverage is not an issue, I see no reason whatsoever to at least use up your current stock. If your OCIs are not greatly extended, and being in GA, then the nitrile ADBV isn't really a big issue. I, as most, prefer the silicone ADBV, but nitrile serve well in millions upon millions of filters around the globe for "normal" applications. As I understand your question, you want to know if the filters are a reasonable interchange to use up your current shelf stock in your application; "yes" is the short answer. No harm should come from their use. Just realize that in the remote chance it does, you're not covered.
Or, most retail stores will allow you to exchange them for full value if they are in the box and in good shape, and then select a different filter.
