For those Quattro owners out there! We just brought the A4 home with 75K miles on her, for my daughter... There is no transmission dip stick... Ok! This is nuts!
I was wanting to change the ATF... There is only a drain plug on the pan and what looks like a fill plug as well.
I assume you drain the fluid. Drop the pan. Clean-Change filter-reinstall pan-fill through fill hole in pan? Until ATF comes out fill hole.
I found the required ATF but it shows $44.95 litre!!!
http://www.europaparts.com/automatic-transmission-fluid-g060162a2.html
Please other Audi A4 owners come forward with some advice.
