Mobil Super High Mileage vs. Valvoline MaxLife
It's often a diester they use to swell the seals slightly.
Quote:
Features and Benefits
Helps extend engine life
Contains seal conditioner to help prevent or control leaks and reduce oil consumption
Helps protects older engines
Guaranteed protection with the Mobil Super Limited Warranty*
Outstanding wear protection under a wide variety of operating conditions
Easy cold starting.
Meets or exceeds the latest industry specifications
API SN / Resource Conserving (Mobil Super High Mileage 5W-20, 5W-30 and 10W-30)
Here is something to consider as well: the ILSAC GF-5 and resource conserving designations.
The Mobil Super High Mileage oil is the only mass-produced high mileage oil to be fully API SN, ILSAC GF-5 and Resource Conserving satisfied. These three items can be quite important for vehicles still under warranty. Most high mileage oils are only API SN certified and not OK for resource conserving or ILSAC performance requirements.
